Changes between Version 3 and Version 4 of TracIni
May 8, 2022, 3:10:54 PM (2 years ago)
  • TracIni
    v3 v4
    66Trac is configured through the **`trac.ini`** file, located in the `<projectenv>/conf` directory. The `trac.ini` configuration file and its parent directory should be writable by the web server.
    8 Trac monitors the timestamp of the file to trigger a complete environment reload and flush its caches when the timestamp changes. Most changes to the configuration will be reflected immediately, though changes to the `[components]` or `[logging]` sections will require restarting the web server. You may also need to restart the web server after creating a [#GlobalConfiguration global configuration] file when none was previously present.
     8Trac monitors the timestamp of the file to trigger an environment reload when the timestamp changes. Most changes to the configuration will be reflected immediately, though changes to the `[components]` or `[logging]` sections will require restarting the web server. You may also need to restart the web server after creating a [#GlobalConfiguration global configuration] file when none was previously present.
    1010== Global Configuration
    1515file = /path/to/global/trac.ini
    1616}}}
    17 Multiple files can be specified using a comma-separated list.
     17Multiple files can be specified using a comma-separated list. Non-absolute paths are relative to the Environment `conf` directory.
    1818
    19 Note that you can also specify a global option file when creating a new project, by adding the option `--inherit=/path/to/global/trac.ini` to [TracAdmin#initenv trac-admin]'s `initenv` command. If you do not do this but nevertheless intend to use a global option file with your new environment, you will have to go through the newly generated `conf/trac.ini` file and delete the entries that will otherwise override those set in the global file.
     19Note that you can also specify a global option file when creating a new project, by adding the option `--inherit=/path/to/global/trac.ini` to [TracAdmin#initenv trac-admin]'s `initenv` command. If you specify `--inherit` but nevertheless intend to use a global option file with your new environment, you will have to go through the newly generated `conf/trac.ini` file and delete the entries that will otherwise override those in the global file.
    2020
    21 There are two more entries in the [[#inherit-section| [inherit] ]] section, `templates_dir` for sharing global templates and `plugins_dir`, for sharing plugins. Those entries can themselves be specified in the shared configuration file, and in fact, configuration files can even be chained if you specify another `[inherit] file` there.
     21There are three more options in the [#inherit-section "[inherit]"] section, [#inherit-templates_dir-option templates_dir] for sharing global templates, [#inherit-htdocs_dir-option htdocs_dir] for sharing global htdocs and [TracIni#inherit-plugins_dir-option plugins_dir], for sharing plugins. Those options can be specified in the shared configuration file, and in fact, configuration files can even be chained if you specify another `[inherit] file` there.
    2222
    23 Note that the templates found in the `templates/` directory of the TracEnvironment have precedence over those found in `[inherit] templates_dir`. In turn, the latter have precedence over the installed templates, so be careful about what you put there. Notably, if you override a default template, refresh your modifications when you upgrade to a new version of Trac. The preferred way to perform TracInterfaceCustomization is still to write a custom plugin doing an appropriate `ITemplateStreamFilter` transformation.
     23Note that the templates found in the `templates/` directory of the TracEnvironment have precedence over those found in `[inherit] templates_dir`. In turn, the latter have precedence over the installed templates, so be careful about what you put there. Notably, if you override a default template, refresh your modifications when you upgrade to a new version of Trac. The preferred way to perform TracInterfaceCustomization is to write a custom plugin doing an appropriate `ITemplateStreamFilter` transformation.
    2424
    2525== Reference for settings
    2626
    27 This is a brief reference of available configuration options, and their default settings.
     27This is a reference of available configuration options, and their default settings.
    2828
    2929Documentation improvements should be discussed on the [trac:MailingList#Trac-dev trac-dev mailing list] or described in a [trac:NewTicket ticket]. Even better, [trac:TracDev/SubmittingPatches submit a patch] against the docstrings in the code.
    30 {{{ #!comment
    31 Please don't waste your time by editing the HTML code below, changes won't be picked up. Instead, follow the above guidance for suggesting documentation improvements.
    32 }}}
     30
    3331[[TracIni]]
    3432
     33== Configure Error Reporting
     34
     35The error reporting page has a //Create// button for reporting
     36issues. The site to which issues are reported depends on the
     37configuration of the Trac site and the user’s permissions.
     38
     39If the user doesn’t possess TRAC_ADMIN, the site to which a user is directed to create a ticket is determined by the [[#project-admin_trac_url-option|"[trac] admin_trac_url"]] setting:
     40
     41* If empty, there will be no //Create// button.
     42* If set to the default value (`.`), the ticket will be
     43  created on the site which the error occurred.
     44* Otherwise the ticket will be created at the site pointed
     45  to by `admin_trac_url`.
     46
     47If [[#project-admin-option|"[project] admin"]] is not empty, the administrator's email address will be rendered on the error page.
     48
     49If the user possesses TRAC_ADMIN, the //Create// button will direct the user to report the issue on trac.edgewall.org. If the error was generated in a plugin, the error will be reported to the project URL provided that the plugin author has included the project URL in the plugin installation data. The user possessing TRAC_ADMIN also sees a traceback and system information on the error page.
     50
    3551----
    36 See also: TracGuide, TracAdmin, TracEnvironment
     52See also: TracAdmin, TracEnvironment
