Changes between Version 3 and Version 4 of TracChangeset
May 8, 2022, 3:10:54 PM (2 years ago)
  • TracChangeset
    v3 v4
    1313
    1414The header shows an overview of the whole changeset.
    15 Here you will find information such as:
     15Here you will find metadata:
    1616
    1717 * Timestamp — When the changeset was commited
    2424
    2525A colored rectangle indicates how the file is affected by the changeset:
    2727 [[span(style=background:#bfb;border:1px solid #999;font-size:80%;margin-right:.5em,''  '')]] Green: Added \\
    2828 [[span(style=background:#f88;border:1px solid #999;font-size:80%;margin-right:.5em,''  '')]] Red: Removed \\
    3030 [[span(style=background:#88f;border:1px solid #999;font-size:80%;margin-right:.5em,''  '')]] Blue: Copied \\
    3131 [[span(style=background:#ccc;border:1px solid #999;font-size:80%;margin-right:.5em,''  '')]] Gray: Moved \\
    32 The color legend is located below the header as a reminder.
     32
     33The color legend is located below the header.
    3334
    3435== Diff Views
    3536
    36 Below the header is the main part of the changeset, the diff view. Each file is shown in a separate section, each of which contains only the regions of the file that are affected by the changeset. There are two different styles to display the diffs: ''inline'' or ''side-by-side''. You can switch between the styles using the preferences form:
     37Below the header is the main part of the changeset, the diff view. Each file is shown in a separate section. There are two different diff styles: ''inline'' and ''side-by-side''. You can switch between the styles using the preferences form:
    3738
    3839 * The ''inline'' style shows the changed regions of a file underneath each other. A region removed from the file will be colored red, an added region will be colored green. If a region was modified, the old version is displayed above the new version. Line numbers indicate the exact position of the change in both the old and the new version of the file.
    4041
    4142In addition, various advanced options are available in the preferences form for adjusting the display of the diffs:
    42  * You can set how many lines are displayed before and after every change; if the value ''all'' is used, then the full file will be shown.
    43  * You can toggle whether blank lines, case changes and white space changes are ignored, thereby letting you find the functional changes more quickly.
     43 * You can set how many lines are displayed before and after every change, or display the changes in the context of the full file.
     44 * You can toggle whether blank lines, case changes and white space changes are ignored. This can be useful in more easily locating the functional changes.
     45 * You can toggle between contextual and unified diff views using the //Tabular// and //Unified// links at the top of each section.
    4446
    4547== The Different Ways to Get a Diff
    4749=== Examining a Changeset
    4850
    49 When viewing a repository check-in, such as when following a changeset [wiki:TracLinks link] or a changeset event in the [wiki:TracTimeline timeline], Trac will display the exact changes made by the check-in.
     51When viewing a repository check-in, such as when following a changeset [TracLinks link] or a changeset event in the [TracTimeline timeline], Trac will display the exact changes made by the check-in.
    5052
    51 There will be also navigation links to the ''Previous Changeset'' to and ''Next Changeset''.
     53There will also be navigation links to the ''Previous Changeset'' and the ''Next Changeset''.
     54
     55=== Downloading a Changeset
     56
     57From the changeset view, the changeset can be downloaded in unified diff format using the links at the bottom of the page. The full content of each file in the changeset can also be downloaded as a zip archive.
    5258
    5359=== Examining Differences Between Revisions
    5965One of the core features of version control systems is the possibility to work simultaneously on different ''Lines of Developments'', commonly called "branches". Trac enables you to examine the exact differences between such branches.
    6066
    61 Using the '''View changes ...''' button in the TracBrowser allows you to enter ''From:'' and ''To:'' path/revision pairs. The resulting set of differences consist of the changes that should be applied to the ''From:'' content to get to the ''To:'' content.
     67Following the '''View changes ...''' button in the TracBrowser leads to the diff page, where you can enter ''From:'' and ''To:'' path/revision pairs. The resulting set of differences consist of the changes that should be applied to the ''From:'' content to get to the ''To:'' content.
    6268
    6369For convenience, it is possible to invert the roles of the ''old'' and the ''new'' path/revision pairs by clicking the ''Reverse Diff'' link on the changeset page.
