Changes between Version 1 and Version 2 of TracBatchModify
02/01/17 00:35:22 (8 years ago)
  • TracBatchModify
    v1 v2
    22[[TracGuideToc]]
    4 Trac supports modifying a batch of tickets in one request from [TracQuery custom query] results .
     4Trac supports modifying a batch of tickets in one request from [TracQuery custom query] results.
    66To perform a batch modification, select the tickets you wish to modify and set the new field values using the section underneath the query results.
    1212== Excluded fields
    1313
    14 Multi-line text fields are not supported, because no valid use-case has been presented for syncing them across several tickets. That restriction applies to the `Description` field as well as to any [TracTicketsCustomFields#AvailableFieldTypesandOptions custom field] of type 'textarea'. However, Trac version 1.0 supports more suitable actions like 'prepend', 'append' or 'search & replace' ([http://trac-hacks.org/ticket/2415 th:#2415]).
     14Multi-line text fields are not supported, because no valid use-case has been presented for syncing them across several tickets. That restriction applies to the `Description` field as well as to any [TracTicketsCustomFields#AvailableFieldTypesandOptions custom field] of type 'textarea'. However, future versions of Trac could support in conjunction with more suitable actions like 'prepend', 'append' or 'search & replace' ([http://trac-hacks.org/ticket/2415 th:#2415]).
