Changes between Version 6 and Version 7 of rfc8_devguide
- Jan 13, 2016, 7:01:34 AM (8 years ago)
rfc8_devguide
v6 v7 35 35 in GDAL/OGR. 36 36 37 * '''b''': C++ bool. Also used for ints with only TRUE/FALSE values in C. 37 38 * '''p''': pointer 38 39 * '''a''': array … … 46 47 * '''o''': c++ object 47 48 * '''os''': CPLString 48 * '''h''': an opaque handle (such as GDALDatasetH). 49 * '''h''': an opaque handle (such as GDALDatasetH). 50 * '''py''': TODO: GByte / unsigned char, correct? 49 51 50 52 Prefix can be stacked. The following are some examples of meaningful … … 56 58 * '''double *pdfMeanRet''': Pointer to a single double. 57 59 * '''GDALRasterBand *poBand''': Pointer to a single object. 60 * '''GByte *pabyHeader''': TODO: This is a non-nul (non-zero) unterminated buffer, correct? 58 61 59 62 It may also be noted that the standard convention for variable names
