| 1 | = RFC 54: Dataset transactions = |
| 2 | |
| 3 | Authors: Even Rouault [[BR]] |
| 4 | Contact: even dot rouault at spatialys.com [[BR]] |
| 5 | Status: Development |
| 6 | |
| 7 | == Summary == |
| 8 | |
| 9 | This RFC introduces an API to offer a transaction mechanism at dataset level and |
| 10 | uses it in the PostgreSQL, SQLite and GPKG drivers. It also reworks |
| 11 | significantly how transactions are handled in the PostgreSQL driver. |
| 12 | It also introduces a generic mechanism to implement an emulation of transactions |
| 13 | for datasources that would not natively support it, and uses it in the FileGDB |
| 14 | driver. |
| 15 | |
| 16 | == Rationale == |
| 17 | |
| 18 | The current abstraction offers a transaction API at the layer level. However, |
| 19 | this is generally misleading since, when it is implemented in DBMS with |
| 20 | BEGIN/COMMIT/ROLLBACK sql statements (PostgreSQL, SQLite, GPKG, PGDump, MSSQLSpatial), |
| 21 | the semantics is really a transaction at database level that spans over all |
| 22 | layers/tables. So even if calling StartTransaction() on a layer, it also extends |
| 23 | on the changes done on other layers. In a very few drivers |
| 24 | StartTransaction()/CommitTransaction() is sometimes used as a mechanism to do |
| 25 | bulk insertion. This is for example the case of WFS, CartoDB, GFT, GME. For some |
| 26 | of them, it could rather be at dataset level too since potentially multiple layer |
| 27 | modifications could be stacked together. |
| 28 | |
| 29 | Furthermode some use cases require updating several layers consistently, hence |
| 30 | the need for a real database level transaction abstraction. |
| 31 | |
| 32 | The current situation of various drivers is the following (some of the below |
| 33 | observations resulting from the analysis are kept mainly for the benefit of developers |
| 34 | that would need to work in the drivers) : |
| 35 | |
| 36 | === PostgreSQL === |
| 37 | |
| 38 | A few facts about cursors used to run GetNextFeature() requests: |
| 39 | |
| 40 | * Cursors are needed for retrieval of huge amount of data without being |
| 41 | memory bound. |
| 42 | * Cursors need transactions to run. |
| 43 | * Default cursors (WITHOUT HOLD) cannot be used outside of the transaction that |
| 44 | created tem |
| 45 | * You cannot modify the structure of a table while the transaction (yes, the |
| 46 | transaction, not the cursor) is still active and if you do that on another |
| 47 | connection, it hangs until the other connection commits or rollbacks) |
| 48 | * Within a transaction, deleted/modified rows are only visible if they are done |
| 49 | before declaring the cursor. |
| 50 | * Cursors WITH HOLD: may be used outside of transaction but cause a copy of |
| 51 | the table to be done --> bad for performance |
| 52 | |
| 53 | Current flaws are : |
| 54 | * one cannot do interleaved layer reading (beyond the |
| 55 | first 500 features fetched, can be easily seen with OGR_PG_CURSOR_PAGE=1) due to |
| 56 | the underlying implicit transaction created to read layer A being closed when the |
| 57 | reading of layer B starts. |
| 58 | * GetFeature() flushes the current transaction and starts a new one to do a |
| 59 | cursor SELECT. Which is unnecessary since we retrieve only one record |
| 60 | * SetAttributeFilter() issues a ResetReading() which currently |
| 61 | FlushSoftTransaction() the ongoing transaction. Can be annoying in a scenario |
| 62 | with long update where you need transactional guarantee |
| 63 | |
| 64 | What works : |
| 65 | * Transaction support at the layer level forwarded to datasource. |
| 66 | * Interleaved writing works (even with copy mode) |
| 67 | |
| 68 | === SQLite/GPKG === |
| 69 | |
| 70 | * Mechanisms used to read table content (sqlite3_prepare() / sqlite3_step()) |
| 71 | do not need transactions. |
| 72 | * Step sees structure modifications (e.g. column addition) if run after |
| 73 | prepared statement but before first step. |
| 74 | * Step sees row modifications/additions as soon as they occur. |
| 75 | * Transaction support at the layer level forwarded to datasource. |
| 76 | |
| 77 | === MySQL === |
| 78 | |
| 79 | * Cannot do interleaved layer reading (reading in one layer resets the other |
| 80 | reading) because of the use of mysql_use_result() that can work with one single |
| 81 | request at a time. mysql_store_result() would be a solution but requires |
| 82 | ingesting the whole result set into memory, which is inpractical for big layers. |
| 83 | * step does not set row changes once the query has started (if done through another |
| 84 | connection, because if done through ExecuteSQL() the long transaction is interrupted) |
| 85 | * No transaction support |
| 86 | |
| 87 | === OCI === |
| 88 | |
| 89 | * Interleaved layer reading works |
| 90 | * Changes done after SELECT seem not to be seen. |
| 91 | * No transaction support |
| 92 | |
| 93 | === FileGDB === |
| 94 | |
| 95 | * Interleaved layer reading works |
| 96 | * Changes done after SELECT seem not to be seen. |
| 97 | * No transaction support |
| 98 | |
| 99 | |
| 100 | == Proposed changes == |
| 101 | |
| 102 | === GDALDataset changes === |
| 103 | |
| 104 | The following methods are added to GDALDataset (and usable by OGRDataSource |
| 105 | which inherits from GDALDataset). |
| 106 | |
| 107 | {{{ |
| 108 | /************************************************************************/ |
| 109 | /* StartTransaction() */ |
| 110 | /************************************************************************/ |
| 111 | |
| 112 | /** |
| 113 | \brief For datasources which support transactions, StartTransaction creates a transaction. |
| 114 | |
| 115 | If starting the transaction fails, will return |
| 116 | OGRERR_FAILURE. Datasources which do not support transactions will |
| 117 | always return OGRERR_UNSUPPORTED_OPERATION. |
| 118 | |
| 119 | Nested transactions are not supported. |
| 120 | |
| 121 | All changes done after the start of the transaction are definitely applied in the |
| 122 | datasource if CommitTransaction() is called. They may be cancelled by calling |
| 123 | RollbackTransaction() instead. |
| 124 | |
| 125 | At the time of writing, transactions only apply on vector layers. |
| 126 | |
| 127 | Datasets that support transactions will advertize the ODsCTransactions capability. |
| 128 | Use of transactions at dataset level is generally prefered to transactions at |
| 129 | layer level, whose scope is rarely limited to the layer from which it was started. |
| 130 | |
| 131 | In case StartTransaction() fails, neither CommitTransaction() or RollbackTransaction() |
| 132 | should be called. |
| 133 | |
| 134 | If an error occurs after a successfull StartTransaction(), the whole |
| 135 | transaction may or may not be implicitely cancelled, depending on drivers. (e.g. |
| 136 | the PG driver will cancel it, SQLite/GPKG not). In any case, in the event of an |
| 137 | error, an explicit call to RollbackTransaction() should be done to keep things balanced. |
| 138 | |
| 139 | By default, when bForce is set to FALSE, only "efficient" transactions will be |
| 140 | attempted. Some drivers may offer an emulation of transactions, but sometimes |
| 141 | with significant overhead, in which case the user must explicitely allow for such |
| 142 | an emulation by setting bForce to TRUE. Drivers that offer emulated transactions |
| 143 | should advertize the ODsCEmulatedTransactions capability (and not ODsCTransactions). |
| 144 | |
| 145 | This function is the same as the C function GDALDatasetStartTransaction(). |
| 146 | |
| 147 | @param bForce can be set to TRUE if an emulation, possibly slow, of a transaction |
| 148 | mechanism is acceptable. |
| 149 | |
| 150 | @return OGRERR_NONE on success. |
| 151 | @since GDAL 2.0 |
| 152 | */ |
| 153 | OGRErr GDALDataset::StartTransaction(CPL_UNUSED int bForce); |
| 154 | |
| 155 | |
| 156 | /************************************************************************/ |
| 157 | /* CommitTransaction() */ |
| 158 | /************************************************************************/ |
| 159 | |
| 160 | /** |
| 161 | \brief For datasources which support transactions, CommitTransaction commits a transaction. |
| 162 | |
| 163 | If no transaction is active, or the commit fails, will return |
| 164 | OGRERR_FAILURE. Datasources which do not support transactions will |
| 165 | always return OGRERR_UNSUPPORTED_OPERATION. |
| 166 | |
| 167 | Depending on drivers, this may or may not abort layer sequential readings that |
| 168 | are active. |
| 169 | |
| 170 | This function is the same as the C function GDALDatasetCommitTransaction(). |
| 171 | |
| 172 | @return OGRERR_NONE on success. |
| 173 | @since GDAL 2.0 |
| 174 | */ |
| 175 | OGRErr GDALDataset::CommitTransaction(); |
| 176 | |
| 177 | /************************************************************************/ |
| 178 | /* RollbackTransaction() */ |
| 179 | /************************************************************************/ |
| 180 | |
| 181 | /** |
| 182 | \brief For datasources which support transactions, RollbackTransaction will roll |
| 183 | back a datasource to its state before the start of the current transaction. |
| 184 | |
| 185 | If no transaction is active, or the rollback fails, will return |
| 186 | OGRERR_FAILURE. Datasources which do not support transactions will |
| 187 | always return OGRERR_UNSUPPORTED_OPERATION. |
| 188 | |
| 189 | This function is the same as the C function GDALDatasetRollbackTransaction(). |
| 190 | |
| 191 | @return OGRERR_NONE on success. |
| 192 | @since GDAL 2.0 |
| 193 | */ |
| 194 | OGRErr GDALDataset::RollbackTransaction(); |
| 195 | }}} |
| 196 | |
| 197 | Note: in the GDALDataset class itself, those methods have an empty implementation |
| 198 | that returns OGRERR_UNSUPPORTED_OPERATION. |
| 199 | |
| 200 | Those 3 methods are mapped at the C level as : |
| 201 | {{{ |
| 202 | OGRErr CPL_DLL GDALDatasetStartTransaction(GDALDatasetH hDS, int bForce); |
| 203 | OGRErr CPL_DLL GDALDatasetCommitTransaction(GDALDatasetH hDS); |
| 204 | OGRErr CPL_DLL GDALDatasetRollbackTransaction(GDALDatasetH hDS); |
| 205 | }}} |
| 206 | |
| 207 | Two news dataset capabilities are added : |
| 208 | * ODsCTransactions: True if this datasource supports (efficient) transactions. |
| 209 | * ODsCEmulatedTransactions: True if this datasource supports transactions through emulation. |
| 210 | |
| 211 | === Emulated transactions === |
| 212 | |
| 213 | A new function OGRCreateEmulatedTransactionDataSourceWrapper() is added for used |
| 214 | by drivers that do not natively support transactions but want an emulation of |
| 215 | them. It could potentially be adopted by any datasource whose data is supportted |
| 216 | by files/directories. |
| 217 | |
| 218 | {{{ |
| 219 | /** Returns a new datasource object that adds transactional behaviour to an existing datasource. |
| 220 | * |
| 221 | * The provided poTransactionBehaviour object should implement driver-specific |
| 222 | * behaviour for transactions. |
| 223 | * |
| 224 | * The generic mechanisms offered by the wrapper class do not cover concurrent |
| 225 | * updates (though different datasource connections) to the same datasource files. |
| 226 | * |
| 227 | * There are restrictions on what can be accomplished. For example it is not |
| 228 | * allowed to have a unreleased layer returned by ExecuteSQL() before calling |
| 229 | * StartTransaction(), CommitTransaction() or RollbackTransaction(). |
| 230 | * |
| 231 | * Layer structural changes are not allowed after StartTransaction() if the |
| 232 | * layer definition object has been returned previously with GetLayerDefn(). |
| 233 | * |
| 234 | * @param poBaseDataSource the datasource to which to add transactional behaviour. |
| 235 | * @param poTransactionBehaviour an implementation of the IOGRTransactionBehaviour interface. |
| 236 | * @param bTakeOwnershipDataSource whether the returned object should own the |
| 237 | * passed poBaseDataSource (and thus destroy it |
| 238 | * when it is destroyed itself). |
| 239 | * @param bTakeOwnershipTransactionBehaviour whether the returned object should own |
| 240 | * the passed poTransactionBehaviour |
| 241 | * (and thus destroy it when |
| 242 | * it is destroyed itself). |
| 243 | * @return a new datasource handle |
| 244 | * @since GDAL 2.0 |
| 245 | */ |
| 246 | OGRDataSource CPL_DLL* OGRCreateEmulatedTransactionDataSourceWrapper( |
| 247 | OGRDataSource* poBaseDataSource, |
| 248 | IOGRTransactionBehaviour* poTransactionBehaviour, |
| 249 | int bTakeOwnershipDataSource, |
| 250 | int bTakeOwnershipTransactionBehaviour); |
| 251 | }}} |
| 252 | |
| 253 | The definition of the IOGRTransactionBehaviour interface is the following: |
| 254 | {{{ |
| 255 | /** IOGRTransactionBehaviour is an interface that a driver must implement |
| 256 | * to provide emulation of transactions. |
| 257 | * |
| 258 | * @since GDAL 2.0 |
| 259 | */ |
| 260 | class CPL_DLL IOGRTransactionBehaviour |
| 261 | { |
| 262 | public: |
| 263 | |
| 264 | /** Start a transaction. |
| 265 | * |
| 266 | * The implementation may update the poDSInOut reference by closing |
| 267 | * and reopening the datasource (or assigning it to NULL in case of error). |
| 268 | * In which case bOutHasReopenedDS must be set to TRUE. |
| 269 | * |
| 270 | * The implementation can for example backup the existing files/directories |
| 271 | * that compose the current datasource. |
| 272 | * |
| 273 | * @param poDSInOut datasource handle that may be modified |
| 274 | * @param bOutHasReopenedDS output boolean to indicate if datasource has been closed |
| 275 | * @return OGRERR_NONE in case of success |
| 276 | */ |
| 277 | virtual OGRErr StartTransaction(OGRDataSource*& poDSInOut, |
| 278 | int& bOutHasReopenedDS) = 0; |
| 279 | |
| 280 | /** Commit a transaction. |
| 281 | * |
| 282 | * The implementation may update the poDSInOut reference by closing |
| 283 | * and reopening the datasource (or assigning it to NULL in case of error). |
| 284 | * In which case bOutHasReopenedDS must be set to TRUE. |
| 285 | * |
| 286 | * The implementation can for example remove the backup it may have done |
| 287 | * at StartTransaction() time. |
| 288 | * |
| 289 | * @param poDSInOut datasource handle that may be modified |
| 290 | * @param bOutHasReopenedDS output boolean to indicate if datasource has been closed |
| 291 | * @return OGRERR_NONE in case of success |
| 292 | */ |
| 293 | virtual OGRErr CommitTransaction(OGRDataSource*& poDSInOut, |
| 294 | int& bOutHasReopenedDS) = 0; |
| 295 | |
| 296 | /** Rollback a transaction. |
| 297 | * |
| 298 | * The implementation may update the poDSInOut reference by closing |
| 299 | * and reopening the datasource (or assigning it to NULL in case of error). |
| 300 | * In which case bOutHasReopenedDS must be set to TRUE. |
| 301 | * |
| 302 | * The implementation can for example restore the backup it may have done |
| 303 | * at StartTransaction() time. |
| 304 | * |
| 305 | * @param poDSInOut datasource handle that may be modified |
| 306 | * @param bOutHasReopenedDS output boolean to indicate if datasource has been closed |
| 307 | * @return OGRERR_NONE in case of success |
| 308 | */ |
| 309 | virtual OGRErr RollbackTransaction(OGRDataSource*& poDSInOut, |
| 310 | int& bOutHasReopenedDS) = 0; |
| 311 | |
| 312 | /** Ask a layer to re-"adopt" its previous feature definition object. |
| 313 | * |
| 314 | * The aim is that the user doesn't see visible object changes. |
| 315 | * |
| 316 | * This method is called if StartTransaction(), CommitTransaction() or |
| 317 | * RollbackTransaction() has closed and reopened a datasource. |
| 318 | * |
| 319 | * The implementation os the method should drop the reference to feature |
| 320 | * definition object it may have currently, assign the poFeatureDefn as |
| 321 | * its current definition object, and take a new reference on it. |
| 322 | * |
| 323 | * The passed poFeatureDefn object is supposed to be the "same" as |
| 324 | * the one the layer has currently (as verified with IsSame()) since |
| 325 | * the emulated datasource wrapper prevents layer structural modifications |
| 326 | * in cases where the user has already called GetLayerDefn() |
| 327 | */ |
| 328 | virtual void ReadoptOldFeatureDefn(OGRDataSource* poDS, |
| 329 | OGRLayer* poLayer, |
| 330 | OGRFeatureDefn* poFeatureDefn) = 0; |
| 331 | }; |
| 332 | }}} |
| 333 | |
| 334 | === OPGRLayer changes === |
| 335 | |
| 336 | At the OGRLayer level, the documentation of GetNextFeature() receives the |
| 337 | following additional information to clarify its semantics : |
| 338 | |
| 339 | {{{ |
| 340 | Features returned by GetNextFeature() may or may not be affected by concurrent |
| 341 | modifications depending on drivers. A guaranteed way of seing modifications in |
| 342 | effect is to call ResetReading() on layers where GetNextFeature() has been called, |
| 343 | before reading again. Structural changes in layers (field addition, deletion, ...) |
| 344 | when a read is in progress may or may not be possible depending on drivers. |
| 345 | If a transaction is committed/aborted, the current sequential reading may or may |
| 346 | not be valid after that operation and a call to ResetReading() might be needed. |
| 347 | }}} |
| 348 | |
| 349 | === PG driver changes === |
| 350 | |
| 351 | Dataset level transactions have been implemented, and use of implicitely |
| 352 | created transactions reworked. |
| 353 | |
| 354 | Interleaved layer reading is now possible. |
| 355 | |
| 356 | GetFeature() has been modified to run without a cursor or a transaction, and |
| 357 | all other calls to transactions have been checked/modified to not reset |
| 358 | accidentally a transaction initiated by the user. |
| 359 | |
| 360 | Below the new behaviour as described in the updated drv_pg_advanced.html help |
| 361 | page : |
| 362 | |
| 363 | {{{ |
| 364 | Efficient sequential reading in PostgreSQL requires to be done within a transaction |
| 365 | (technically this is a CURSOR WITHOUT HOLD). |
| 366 | So the PG driver will implicitely open such a transaction if none is currently |
| 367 | opened as soon as a feature is retrieved. This transaction will be released if |
| 368 | ResetReading() is called (provided that no other layer is still being read). |
| 369 | |
| 370 | If within such an implicit transaction, an explicit dataset level StartTransaction() |
| 371 | is issued, the PG driver will use a SAVEPOINT to emulate properly the transaction |
| 372 | behaviour while making the active cursor on the read layer still opened. |
| 373 | |
| 374 | If an explicit transaction is opened with dataset level StartTransaction() |
| 375 | before reading a layer, this transaction will be used for the cursor that iterates |
| 376 | over the layer. When explicitly committing or rolling back the transaction, the |
| 377 | cursor will become invalid, and ResetReading() should be issued again to restart |
| 378 | reading from the beginning. |
| 379 | |
| 380 | With the above rules, the below examples show the SQL instructions that are |
| 381 | run when using the OGR API in different scenarios. |
| 382 | |
| 383 | |
| 384 | lyr1->GetNextFeature() BEGIN (implict) |
| 385 | DECLARE cur1 CURSOR FOR SELECT * FROM lyr1 |
| 386 | FETCH 1 IN cur1 |
| 387 | |
| 388 | lyr2->GetNextFeature() DECLARE cur2 CURSOR FOR SELECT * FROM lyr2 |
| 389 | FETCH 1 IN cur2 |
| 390 | |
| 391 | lyr1->GetNextFeature() FETCH 1 IN cur1 |
| 392 | |
| 393 | lyr2->GetNextFeature() FETCH 1 IN cur2 |
| 394 | |
| 395 | lyr1->CreateFeature(f) INSERT INTO cur1 ... |
| 396 | |
| 397 | lyr1->ResetReading() CLOSE cur1 |
| 398 | |
| 399 | lyr2->ResetReading() CLOSE cur2 |
| 400 | COMMIT (implicit) |
| 401 | |
| 402 | |
| 403 | |
| 404 | ds->StartTransaction() BEGIN |
| 405 | |
| 406 | lyr1->GetNextFeature() DECLARE cur1 CURSOR FOR SELECT * FROM lyr1 |
| 407 | FETCH 1 IN cur1 |
| 408 | |
| 409 | lyr2->GetNextFeature() DECLARE cur2 CURSOR FOR SELECT * FROM lyr2 |
| 410 | FETCH 1 IN cur2 |
| 411 | |
| 412 | lyr1->CreateFeature(f) INSERT INTO cur1 ... |
| 413 | |
| 414 | lyr1->ResetReading() CLOSE cur1 |
| 415 | |
| 416 | lyr2->ResetReading() CLOSE cur2 |
| 417 | |
| 418 | ds->CommitTransaction() COMMIT |
| 419 | |
| 420 | |
| 421 | |
| 422 | ds->StartTransaction() BEGIN |
| 423 | |
| 424 | lyr1->GetNextFeature() DECLARE cur1 CURSOR FOR SELECT * FROM lyr1 |
| 425 | FETCH 1 IN cur1 |
| 426 | |
| 427 | lyr1->CreateFeature(f) INSERT INTO cur1 ... |
| 428 | |
| 429 | ds->CommitTransaction() CLOSE cur1 (implicit) |
| 430 | COMMIT |
| 431 | |
| 432 | lyr1->GetNextFeature() FETCH 1 IN cur1 ==> Error since the cursor was closed with the commit. Explicit ResetReading() required before |
| 433 | |
| 434 | |
| 435 | |
| 436 | lyr1->GetNextFeature() BEGIN (implicit) |
| 437 | DECLARE cur1 CURSOR FOR SELECT * FROM lyr1 |
| 438 | FETCH 1 IN cur1 |
| 439 | |
| 440 | ds->StartTransaction() SAVEPOINT savepoint |
| 441 | |
| 442 | lyr1->CreateFeature(f) INSERT INTO cur1 ... |
| 443 | |
| 444 | ds->CommitTransaction() RELEASE SAVEPOINT savepoint |
| 445 | |
| 446 | lyr1->ResetReading() CLOSE cur1 |
| 447 | COMMIT (implicit) |
| 448 | |
| 449 | |
| 450 | Note: in reality, the PG drivers fetches 500 features at once. The FETCH 1 |
| 451 | is for clarity of the explanation. |
| 452 | }}} |
| 453 | |
| 454 | It is recommended to do operations within explicit transactions for ease of mind |
| 455 | (some troubles fixing ogr_pg.py, but which does admitedly weird things like |
| 456 | reopening connections, which does not fly very well with 'implicit' transactions) |
| 457 | |
| 458 | === GPKG and SQLite driver changes === |
| 459 | |
| 460 | Dataset level transactions have been implemented. A few fixes made here and there |
| 461 | to avoid reseting accidentally a transaction initiated by the user. |
| 462 | |
| 463 | === FileGDB driver changes === |
| 464 | |
| 465 | The FileGDB driver uses the above described emulation to offer a transaction |
| 466 | mechanism. This works by backing up the |
| 467 | current state of a geodatabase when StartTransaction(force=TRUE) is called. |
| 468 | If the transaction is committed, the backup copy is destroyed. If the transaction |
| 469 | is rolled back, the backup copy is restored. So this might be costly when operating |
| 470 | on huge geodatabases. |
| 471 | Note that this emulation has an unspecified behaviour in case of concurrent updates |
| 472 | (with different connections in the same or another process). |
| 473 | |
| 474 | == SWIG bindings (Python / Java / C# / Perl) changes == |
| 475 | |
| 476 | The following additions have been done : |
| 477 | * Dataset.StartTransaction(int force=FALSE) |
| 478 | * Dataset.CommitTransaction() |
| 479 | * Dataset.RollbackTransaction() |
| 480 | * ogr.ODsCTransactions constant |
| 481 | * ogr.ODsCEmulatedTransactions constant |
| 482 | |
| 483 | == Utilities == |
| 484 | |
| 485 | ogr2ogr now uses dataset transactions (instead of layer transactions) if |
| 486 | ODsCTransactions is advertized. |
| 487 | |
| 488 | == Documentation == |
| 489 | |
| 490 | New/modified API are documented. MIGRATION_GUIDE.TXT updated with mention |
| 491 | to below compatibility issues. |
| 492 | |
| 493 | == Test Suite == |
| 494 | |
| 495 | The test suite is extended to test |
| 496 | * updated drivers: PG, GPKG, SQLite, FileGDB |
| 497 | * use of database transactions by ogr2ogr |
| 498 | |
| 499 | == Compatibility Issues == |
| 500 | |
| 501 | As described above, subtle behaviour changes can be observed with the PG driver, |
| 502 | related to implicit transactions that were flushed before and are no longer now, |
| 503 | but this should hopefully be restricted to non-typical use cases. So some cases that "worked" before might |
| 504 | no longer work, but the new behaviour should hopefully be more understandable. |
| 505 | |
| 506 | The PG and SQLite drivers could accept apparently nested calls to StartTransaction() |
| 507 | (at the layer level). This is no longer possible since they are now redirected |
| 508 | to dataset transactions, that explicitely do not support it. |
| 509 | |
| 510 | == Out of scope == |
| 511 | |
| 512 | The following drivers that implement BEGIN/COMMIT/ROLLBACK could be later |
| 513 | enhanced to support dataset transactions: OCI, MySQL, MSSQLSpatial. |
| 514 | |
| 515 | GFT, CartoDB, WFS could also benefit for dataset transactions. |
| 516 | |
| 517 | VRT currently supports layer transactions (if the underlying dataset support it, |
| 518 | and excluding union layers). If dataset transaction were to be implemented, should |
| 519 | it consist in forwarding dataset transaction to source dataset(s) ? Implementation |
| 520 | might be complicated in case the same dataset is used by multiple sources, |
| 521 | but more fundamentally one cannot guarantee ACID on multiple datasets. |
| 522 | |
| 523 | == Related tickets == |
| 524 | |
| 525 | A proposed revision on how transactions are implemented in the PG driver was |
| 526 | proposed a long time ago (https://trac.osgeo.org/gdal/ticket/1265) to solve |
| 527 | some of the above issues. The patch no longer applies but it is expected that |
| 528 | the changes done for this RFC cover the issues that the ticket wanted to address. |
| 529 | |
| 530 | == Implementation == |
| 531 | |
| 532 | Implementation will be done by Even Rouault ([http://spatialys.com Spatialys]), |
| 533 | and sponsored by [http://www.linz.govt.nz/ LINZ (Land Information New Zealand)]. |
| 534 | |
| 535 | The proposed implementation lies in the "rfc54_dataset_transactions" branch of the |
| 536 | https://github.com/rouault/gdal2/tree/rfc54_dataset_transactions repository. |
| 537 | |
| 538 | The list of changes: https://github.com/rouault/gdal2/compare/rfc54_dataset_transactions |
| 539 | |
| 540 | == Voting history == |
| 541 | |
| 542 | TBD |
