Changes between Version 1 and Version 2 of rfc36_open_by_drivername
- Oct 3, 2011, 11:56:33 AM (13 years ago)
v1 v2 49 49 == Issues == 50 50 51 But it is important to note that some drivers already accept a "driver-name:" entry and knows how to deal with it directly. 51 But it is important to note that some drivers already accept a "driver-name:" entry and knows how to deal with it directly. In that case if the driver name entered is exactly the name of a driver then it will take advantage of the proposed mechanism avoiding the probing mechanism. Therefor entries like "GTIFF_RAW:xxx", "GEOR:xxx", "JPEG_SUBFILE:xxx" will fail to be loaded direct by any driver, since they are not real drivers names. The control will be passed to the driver probing loop that will eventually open the file. 52 52 53 In that case if the driver name entered is exactly the name of a driver then it will take advantage of the proposed mechanism avoiding the probing mechanism, ex.:54 55 {{{56 gdalinfo georaster:mike/bear@dbg,arch,img,id=12357 }}}58 59 So entries like "GTIFF_RAW:", "GEOR:", "JPEG_SUBFILE:" will fail to be loaded direct by any driver, since they are not real drivers names, and in that case the datasets will be opened by the existing driver probing mechanism.60
