Changes between Version 1 and Version 2 of rfc35_deletereorderalterfielddefn
- May 7, 2011, 10:09:44 AM (13 years ago)
v1 v2 171 171 172 172 The autotest suite will be extended to test the implementation of the new API for the Shapefile driver. An example 173 of the use of the new API is attached to ticket #2671 ( rfc35_test.py) and will be turned into unit tests.173 of the use of the new API is attached to ticket #2671 ([http://trac.osgeo.org/gdal/attachment/ticket/2671/rfc35_test.py rfc35_test.py]) and will be turned into unit tests. 174 174 175 175 == Implementation == … … 177 177 Implementation will be done by Even Rouault in GDAL/OGR trunk. Changes in Shapelib will need to be 178 178 pushed into upstream CVS by a Shapelib committer. The proposed implementation is attached as 179 a patch in ticket #2671 ( rfc35.patch).179 a patch in ticket #2671 ([http://trac.osgeo.org/gdal/attachment/ticket/2671/rfc35.patch rfc35.patch]).
