| 30 | Note that the old interfaces using "long" are already 64bit on 64bit operating systems (excluding Windows target compilers where long is 32bit even on 64bit builds), so there is little harm to applications continuing to use these interfaces on 64bit operating systems. |
| 31 | |
| 32 | A layer that can discover in a relatively cheap way that it holds features with 64bit FID should advertize the OLMD_FID64 metadata item to "YES", so ogr2ogr can pass the FID64 creation option to drivers that support it. |
| 33 | |
| 34 | The OGRLayer class allows several operations based on the FID. The signature of these will be *altered* to accept GIntBig instead of long. In theory this should not require any changes to application code since long can be converted to GIntBig losslessly. However, all existing OGR drivers require changes, including private drivers. This will also result in a backwards incompatible change in the C ABI. While we are at it, we want GetFeatureCount() to be able to return more than 2 billion record (currently returning 32 bit integer). For the same reason as it is dangerous modifying the return type of GetFeatureCount(), we introduce GetFeatureCount64() and deprecate GetFeatureCount(), removing its virtual attribute. |
| 35 | |
| 36 | So at the OGRLayer C++ class level: |
| 40 | virtual OGRErr SetNextByIndex( GIntBig nIndex ); |
| 41 | int GetFeatureCount( int bForce = TRUE ) CPL_WARN_DEPRECATED("Use GetFeatureCount64() instead"); |
| 42 | virtual GIntBig GetFeatureCount64( int bForce = TRUE ); |
| 43 | }}} |
| 44 | |
| 45 | At the C API level : |
| 46 | {{{ |
| 47 | OGRFeatureH CPL_DLL OGR_L_GetFeature( OGRLayerH, GIntBig ); |
| 48 | OGRErr CPL_DLL OGR_L_DeleteFeature( OGRLayerH, GIntBig ); |
| 49 | OGRErr CPL_DLL OGR_L_SetNextByIndex( OGRLayerH, GIntBig ); |
| 50 | int CPL_DLL OGR_L_GetFeatureCount( OGRLayerH, int ) CPL_WARN_DEPRECATED("Use OGR_L_GetFeatureCount64() instead"); |
| 51 | GIntBig CPL_DLL OGR_L_GetFeatureCount64( OGRLayerH, int ); |
65 | | Furthermore, the new interfaces will internally support setting/getting integer fields, and the integer field methods will support getting/setting 64bit integer fields so that one case can be used for both field types where convenient. |
| 89 | At the C level, the following functions are added : |
| 90 | {{{ |
| 91 | GIntBig CPL_DLL OGR_F_GetFieldAsInteger64( OGRFeatureH, int ); |
| 92 | const GIntBig CPL_DLL *OGR_F_GetFieldAsInteger64List( OGRFeatureH, int, int * ); |
| 93 | void CPL_DLL OGR_F_SetFieldInteger64( OGRFeatureH, int, GIntBig ); |
| 94 | void CPL_DLL OGR_F_SetFieldInteger64List( OGRFeatureH, int, int, const GIntBig * ); |
| 95 | }}} |
| 96 | |
| 97 | Furthermore, the new interfaces will internally support setting/getting integer fields, and the integer field methods will support getting/setting 64bit integer fields so that one case can be used for both field types where convenient (except GetFieldAsInteger64List() that can only operate on Integer64List fields) |
| 98 | |
| 99 | A GDAL_DMD_CREATIONFIELDDATATYPES = "DMD_CREATIONFIELDDATATYPES" driver metadata item is added so as drivers to be able to declare the field types they support on creation. For example "Integer Integer64 Real String Date DateTime Time IntegerList Integer64List RealList StringList Binary". Commonly used drivers will be updated to declare it. |
| 100 | |
| 101 | == OGR SQL == |
| 102 | |
| 103 | A SWQ_INTEGER64 internal type is added so as to be able to map/from OFTInteger64 fields. The int_value member of the swq_expr_node class is extended from int to GIntBig (so both SWQ_INTEGER and SWQ_INTEGER64 refer to that member). |
69 | | No thoughts yet on the impact to the various SWIG derived interfaces. |
| 107 | Typing issues are less critical in those languages, so : |
| 108 | * GetFID(), GetFeatureCount() have been changed to return a 64 bit integer |
| 109 | * SetFID(), GetFeature(), DeleteFeature(), SetNextByIndex() have been changed to accept a 64 bit integer as argument |
| 110 | * GetFieldAsInteger64() and SetFieldInteger64() have been added |
| 111 | * In Python, GetField(), SetField() can accept/return 64 bit values |
| 112 | * GetFieldAsInteger64List() and SetFieldInteger64List() have been added (Python only, due to lack of relevant typemaps for other languages) |
79 | | For prototyping purposes the Shapefile, and PostGIS drivers have been updated to properly support 64bit integer fields. |
80 | | |
81 | | Also, all drivers need to be updated to use GIntBig for the FID in the GetFeature() and DeleteFeature() interfaces. |
| 130 | Apart from the mechanical changes due to interface changes, the detailed list of changes is : |
| 131 | * Shapefile: OFTInteger fields are created by default with a width of 9 characters, so to be unambiguously read as OFTInteger (and if specifying integer that require 10 or 11 characters. the field is dynamically extended like managed since a few versions). OFTInteger64 fields are created by default with a width of 18 digits, so to be unambiguously read as OFTInteger64, and extented to 19 or 20 if needed. Integer fields of width between 10 and 18 will be read as OFTInteger64. Above they will be treated as OFTReal. In previous GDAL versions, Integer fields were created with a default with of 10, and thus will be now read as OFTInteger64. An open option, DETECT_TYPE=YES, can be specified so as OGR does a full scan of the DBF file to see if integer fields of size 10 or 11 hold 32 bit or 64 bit values and adjust the type accordingly (and same for integer fields of size 19 or 20, in case of overflow of 64 bit integer, OFTReal is chosen) |
| 132 | * PG: updated to read and create OFTInteger64 as INT8 and OFTInteger64List as bigint[]. 64 bit FIDs are supported. By default, on layer creation, the FID field is created as a SERIAL (32 bit integer) to avoid compatibility issues. The FID64=YES creation option can be passed to create it as a BIGSERIAL instead. If needed, the drivers will dynamically alter the schema to extend a 32 bit integer FID field to 64 bit. GetFeatureCount64() modified to return 64 bit values. OLMD_FID64 = "YES" advertized as soon as the FID column is 64 bit. |
| 133 | * PGDump: Integer64, Integer64List and 64 bit FID supported in read/write. FID64=YES creation option available. |
| 134 | * GeoJSON: Integer64, Integer64List and 64 bit FID supported in read/write. The 64 bit variants are reported only if needed, otherwise OFTInteger/OFTIntegerList is used. OLMD_FID64 = "YES" advertized if needed |
| 135 | * CSV: Integer64 supported in read/write, including the autodetection feature of field types. |
| 136 | * GPKG: Integer64 and 64 bit FID supported in read/write. Conforming with the GeoPackage spec, "INT" or "INTEGER" columns are considered 64 bits, whereas "MEDIUMINT" is considered 32 bit. OLMD_FID64 = "YES" advertized as soon as MAX(fid_column) is 64 bit. GetFeatureCount64() modified to return 64 bit values. |
| 137 | * SQLite: Integer64 and 64 bit FID supported in read/write. On write, Integer64 are createad as "BIGINT" and on read BIGINT or INT8 are considered as Integer64. However it might be possible that databases produced by other tools are created with "INTEGER" and hold 64 bit values, in which case OGR will not be able to detect it. The OGR_PROMOTE_TO_INTEGER64=YES configuration option can then be passed to workaround that issue. OLMD_FID64 = "YES" advertized as soon as MAX(fid_column) is 64 bit. GetFeatureCount64() modified to return 64 bit values. |
| 138 | * MySQL: Integer64 and 64 bit FID supported in read/write. Similarly to PG, FID column is created as 32 bit by default, unless FID64=YES creation option is specified. OLMD_FID64 = "YES" advertized as soon as the FID column is 64 bit. GetFeatureCount64() modified to return 64 bit values. |
| 139 | * OCI: Integer64 and 64 bit FID supported in read/write. Detecting Integer/Integer64 on read is tricky since there's only a NUMBER SQL type with a field width. It is assumed that if the width is <= 9 or if it is the unspecified value (38), then it is a Integer. On creation, OGR will set a width of 20 for OFTInteger64, so a NUMBER without decimal part and with a width of 20 will be considered as a Integer64. |
| 140 | * MEM: Integer64 and 64 bit FID supported in read/write. GetFeatureCount64() modified to return 64 bit values. |
| 141 | * VRT: Integer64, Integer64List and 64 bit FID supported in read/write. GetFeatureCount64() modified to return 64 bit values. |
| 142 | * JML: Integer64 supported on creation (created as "OBJECT"). On read, returned as String |
| 143 | * GML: Integer64, Integer64List and 64 bit FID supported in read/write. GetFeatureCount64() modified to return 64 bit values. |
| 144 | * WFS: Integer64, Integer64List and 64 bit FID supported in read/write. GetFeatureCount64() modified to return 64 bit values. |
| 145 | * CartoDB: Integer64 supported on creation. On read returned as Real (CartoDB only advertizes a 'Number' type). GetFeatureCount64() modified to return 64 bit values. |
| 146 | * XLSX: Integer64 supported in read/write. |
| 147 | * ODS: Integer64 supported in read/write. |
| 148 | * MSSQLSpatial: GetFeatureCount64() modified to return 64 bit values. No Integer64 support implemented although could likely be done. |
| 149 | * OSM: FID is now always set even when sizeof(long) != 8 |
| 150 | * LIBKML: KML 'uint' advertized as Integer64. |
