Changes between Version 9 and Version 10 of rfc24_progressive_data_support
- Aug 20, 2008, 1:20:14 PM (16 years ago)
v9 v10 19 19 == Implementation == 20 20 21 The implementation is a definition of an interface, currently the most convenient JPIP streaming developer library is [http://www.kakadusoftware.com Kakadu] however since GDAL is also developer library only stubs can be distributed to conform to Kakadu licensing [http://trac.osgeo.org/gdal/wiki/JP2KAK JP2KAK]. Commercial vendors are also interested in using GDAL for streaming support and a standard interface will allow these commercial plugins to be incorporated. e.g. [http://www.gdal.org/frmt_jp2ecw.html ECW], [http://www.gdal.org/frmt_mrsid.html MrSID].21 The implementation is a definition of an interface, in particular and overloaded function definition for RasterIO. Concrete implementations of this interface will follow. Currently the most convenient JPIP streaming developer library is [http://www.kakadusoftware.com Kakadu] however since GDAL is also developer library only stubs can be distributed to conform to Kakadu licensing [http://trac.osgeo.org/gdal/wiki/JP2KAK JP2KAK]. Commercial vendors are also interested in using GDAL for streaming support and a standard interface will allow these commercial plugins to be incorporated. e.g. [http://www.gdal.org/frmt_jp2ecw.html ECW], [http://www.gdal.org/frmt_mrsid.html MrSID]. 22 22 23 23 === Proposed Progressive Streaming Sequence of Events === 24 24 25 ''Sequence shows GDALDataset, same sequence for GDALRasterBand'' 26 25 27 [[Image(progressive.jpg)]] 26 28
