Changes between Version 5 and Version 6 of rfc23_ogr_unicode
- Apr 25, 2008, 12:43:54 PM (16 years ago)
rfc23_ogr_unicode
v5 v6 57 57 == iconv() == 58 58 59 It is proposed to implement the CPL String::recode() method using the iconv()59 It is proposed to implement the CPLRecode() method using the iconv() 60 60 and related functions when available. 61 61 … … 66 66 to use libiconv in preference to the system iconv() even when it is available. 67 67 68 If iconv() is not available, a stub implementation of the CPLStringservices68 If iconv() is not available, a stub implementation of the recode services 69 69 will be provided which: 70 70 … … 74 74 * Implements recoding from "UTF-8" to "ASCII" by turning all non-ASCII multi-byte characters to '?'. 75 75 76 This hope sfully gives us a weak operational status when built without iconv(), but full operation when it is available.76 This hopefully gives us a weak operational status when built without iconv(), but full operation when it is available. 77 77 78 78 The --with-iconv=<arg> option will be added to configure. The argument can be … … 112 112 113 113 Frank Warmerdam will implement the core iconv() capabilities, the 114 CPL Stringadditions and update the ODBC driver. Other OGR drivers would be114 CPLRecode() additions and update the ODBC driver. Other OGR drivers would be 115 115 updated as time and demand mandates to conform to the definitions in this RFC by 116 116 interested developers.
