Changes between Version 8 and Version 9 of rfc20_srs_axes
Show
01/10/08 14:04:32 (5 years ago)
warmerdam
Add some additional methods and details.
  • rfc20_srs_axes
    v8 v9
    5454}}}
    5555
     56Fetch information about one axis (iAxis is zero based).
     57
    5658{{{
    5759    OGRErr      SetAxes( const char *pszTargetKey,
    6567    int         EPSGTreatsAsLatLong();
    6668}}}
     69
     70Returns true based on the EPSG code if EPSG would like this coordinate system to be treated as lat/long.  This is useful in contexts like WMS 1.3 where EPSG:4326 needs to be interpreted as lat/long due to the standard.
     71
     72{{{
     73       OGRErr      importFromEPSGA( int );
     74}}}
     75
     76This works like importFromEPSG() but will assign the ESPG defined AXIS definition.
    6777
    6878Note that OGRSpatialReference::!StripNodes( "AXIS" ); can be used to strip axis definitions where they are not desired.
    8191 * importFromEPSG() will continue to *not* set AXIS values for GEOGCS coordinate systems.
    8292 * importFromEPSG() will now set axis values for projected coordinate systems (at least in cases like Krovak where it is a non-default axis orientation).
     93 * importFromEPSG() will be implemented by calling importFromEPSGA() and stripping off axis definitions from the geographic portion of the returned definition.
     94
     95=== !SetFromUserInput() ===
     96
     97 * This method will have one new option which is a value prefixed by EPSGA: will be passed to importFromEPSGA() (similarly to EPSG:n being passed to importFromEPSG()).
    8398
    8499== OGRCoordinateTransformation ==
