Changes between Version 13 and Version 14 of rfc20_srs_axes
- Jan 14, 2008, 8:53:08 PM (16 years ago)
rfc20_srs_axes
v13 v14 112 112 If AXIS values are set on source and/or destination coordinate system, the OGRCoordinateTransformation code will take care of converting into normal easting/northing before calling PROJ.4. 113 113 114 The CPL config option "IGNORE_AXIS_ORIENTATION" may also be set to " FALSE" to disable OGRCoordinateTransformation's checking, and application of axis orientation changes. Effectively this is a backdoor to disable the core effects of the RFC.114 The CPL config option "IGNORE_AXIS_ORIENTATION" may also be set to "TRUE" to disable OGRCoordinateTransformation's checking, and application of axis orientation changes. Effectively this is a backdoor to disable the core effects of the RFC. 115 115 116 116 == Drivers Affected ==
