Changes between Version 1 and Version 2 of mdbtools
- Nov 24, 2008, 2:50:00 PM (15 years ago)
mdbtools
v1 v2 5 5 However the ''mdbtools'' package is currently unmaintened upstream and suffer from a few bugs that prevent the latest released version to be used successfully for the OGR PGeo driver. 6 6 7 You can apply the below mdbtools-0.5.99.0.6pre1.0.20051109-odbc.patch patch on top of the [http://ftp.de.debian.org/debian/pool/main/m/mdbtools/mdbtools_0.5.99.0.6pre1.0.20051109.orig.tar.gz Debian mdbtools_0.5.99.0.6pre1.0.20051109.orig.tar.gz] to improve the situation 7 You can apply the below mdbtools-0.5.99.0.6pre1.0.20051109-odbc.patch patch on top of the [http://ftp.de.debian.org/debian/pool/main/m/mdbtools/mdbtools_0.5.99.0.6pre1.0.20051109.orig.tar.gz Debian mdbtools_0.5.99.0.6pre1.0.20051109.orig.tar.gz] to improve the situation a bit. Note that this patch is only of band-aid quality and that the implementation of SQLGetData() would require a non trivial amount of work to make it work reliably. Currently, this will truncate retrieve data to 512 characters, a limit which can be easily hit by geometies of type linestring or polygons. 8 8
