Changes between Version 31 and Version 32 of frmts_wtkraster.html
- Oct 29, 2010, 5:56:10 AM (13 years ago)
v31 v32 74 74 == '''3.1 - Loading raster data in the database''' == 75 75 76 The GDAL PostGIS Raster driver isn't able to load raster data yet. For this proposal, you'll have to use '''raster2pgsql''' script. This loader script is included with the PostGIS installation, under the ''raster/scripts/python'' subdirectory. To check the syntax of the script, execute this command from that subdirectory:76 The GDAL PostGIS Raster driver isn't able to load raster data yet. For this, you'll have to use '''raster2pgsql''' script. This loader script is included with the PostGIS installation, under the ''raster/scripts/python'' subdirectory. To check the syntax of the script, execute this command from that subdirectory: 77 77 78 78 {{{
