Changes between Version 30 and Version 31 of frmts_wtkraster.html
- Oct 29, 2010, 5:55:47 AM (13 years ago)
v30 v31 72 72 = '''3 - Using GDAL PostGIS Raster driver''' = 73 73 74 == '''3.1 - Loading raster data ''' ==74 == '''3.1 - Loading raster data in the database''' == 75 75 76 76 The GDAL PostGIS Raster driver isn't able to load raster data yet. For this proposal, you'll have to use '''raster2pgsql''' script. This loader script is included with the PostGIS installation, under the ''raster/scripts/python'' subdirectory. To check the syntax of the script, execute this command from that subdirectory: … … 131 131 }}} 132 132 133 == '''3.2 - Reading data''' ==133 == '''3.2 - Reading raster data from the database''' == 134 134 135 135 If you want to use the GDAL WKT Raster driver, you must provide a '''connection string''' as Dataset's name. The syntax of this connection string is (the quotes may be ommitted):
