| 11 | | As all Wiki pages, this page is editable, this means that you can |
| 12 | | modify the contents of this page simply by using your |
| 13 | | web-browser. Simply click on the "Edit this page" link at the bottom |
| 14 | | of the page. WikiFormatting will give you a detailed description of |
| 15 | | available Wiki formatting commands. |
| | 7 | * [http://trac.osgeo.org/gdal/newticket Submit a Bug Ticket] |
| | 8 | * [http://trac.osgeo.org/gdal/report/1?sort=ticket&asc=0 View All Open Tickets] |
| | 9 | |
| | 10 | == User Wiki == |
| 17 | | "[wiki:TracAdmin trac-admin] ''yourenvdir'' initenv" created |
| 18 | | a new Trac environment, containing a default set of wiki pages and some sample |
| 19 | | data. This newly created environment also contains |
| 20 | | [wiki:TracGuide documentation] to help you get started with your project. |
| 21 | | |
| 22 | | You can use [wiki:TracAdmin trac-admin] to configure |
| 23 | | [http://trac.edgewall.org/ Trac] to better fit your project, especially in |
| 24 | | regard to ''components'', ''versions'' and ''milestones''. |
| 25 | | |
| 26 | | |
| 27 | | TracGuide is a good place to start. |
| 28 | | |
| 29 | | Enjoy! [[BR]] |
| 30 | | ''The Trac Team'' |
| 31 | | |
| 32 | | == Starting Points == |
| 33 | | |
| 34 | | * TracGuide -- Built-in Documentation |
| 35 | | * [http://trac.edgewall.org/ The Trac project] -- Trac Open Source Project |
| 36 | | * [http://trac.edgewall.org/wiki/TracFaq Trac FAQ] -- Frequently Asked Questions |
| 37 | | * TracSupport -- Trac Support |
| | 12 | == Developer Wiki == |
