Changes between Version 28 and Version 29 of WCS+interoperability
- Nov 14, 2017, 11:32:46 PM (6 years ago)
v28 v29 43 43 == Test data 44 44 45 Sample image A from the WCS KISS dataset 45 **Note to authors** 46 47 Add !DescribeCoverage documents from different servers as annexes. Name should reveal the server and WCS version. 48 49 Sample image A from the WCS KISS dataset (GeoTIFF as an annex) 46 50 47 51 [[Image(WCS_KISS_Image_A.png)]] … … 49 53 50 54 51 Sample image B from the WCS KISS dataset 55 Sample image B from the WCS KISS dataset (GeoTIFF as an annex) 52 56 53 57 [[Image(WCS_KISS_Image_B.png)]] … … 59 63 60 64 61 Images are of type "pixel is area". The pixel centers showin this image65 Images are of type "pixel is area". The pixel centers are also shown in this image 62 66 63 67 … … 84 88 A.tfw 85 89 90 91 {{{ 86 92 1 93 0 94 0 95 -1 96 115.5 97 32.5 98 }}} 87 99 88 089 90 091 92 -193 94 115.595 96 32.597 100 98 101 B.tfw 99 102 103 104 {{{ 100 105 1 101 102 106 0 103 104 107 0 105 106 108 -1 107 108 109 114.5 109 110 110 33.5 111 }}} 111 112 112 113 … … 144 145 Band 3 Block=2x3 Type=Byte, ColorInterp=Blue 145 146 }}} 147 148 149 150 151 {{{ 152 Driver: GTiff/GeoTIFF 153 Files: WCS_KISS_B.tif 154 Size is 4, 5 155 Coordinate System is: 156 GEOGCS["WGS 84", 157 DATUM["WGS_1984", 158 SPHEROID["WGS 84",6378137,298.257223563, 159 AUTHORITY["EPSG","7030"]], 160 AUTHORITY["EPSG","6326"]], 161 PRIMEM["Greenwich",0], 162 UNIT["degree",0.0174532925199433], 163 AUTHORITY["EPSG","4326"]] 164 Origin = (114.000000000000000,34.000000000000000) 165 Pixel Size = (1.000000000000000,-1.000000000000000) 166 Metadata: 167 AREA_OR_POINT=Area 168 Image Structure Metadata: 169 INTERLEAVE=PIXEL 170 Corner Coordinates: 171 Upper Left ( 114.0000000, 34.0000000) (114d 0' 0.00"E, 34d 0' 0.00"N) 172 Lower Left ( 114.0000000, 29.0000000) (114d 0' 0.00"E, 29d 0' 0.00"N) 173 Upper Right ( 118.0000000, 34.0000000) (118d 0' 0.00"E, 34d 0' 0.00"N) 174 Lower Right ( 118.0000000, 29.0000000) (118d 0' 0.00"E, 29d 0' 0.00"N) 175 Center ( 116.0000000, 31.5000000) (116d 0' 0.00"E, 31d30' 0.00"N) 176 Band 1 Block=4x5 Type=Byte, ColorInterp=Red 177 Band 2 Block=4x5 Type=Byte, ColorInterp=Green 178 Band 3 Block=4x5 Type=Byte, ColorInterp=Blue 179 }}}
