Changes between Version 20 and Version 21 of WCS+interoperability
- Nov 14, 2017, 1:35:41 AM (7 years ago)
v20 v21 17 17 == GDAL WCS Driver and Interoperability 18 18 19 This table describes the interoperability of the GDAL WCS driver (new version, currently in development) with various WCS servers. 19 This table describes the interoperability of the GDAL WCS driver (new version, currently in development) with various WCS servers. (Results are tentative. Also, ArcGIS WCS server serving data with inverted axis CRS is not yet tested, and MapServer and Rasdaman serving data in normal CRS is not yet tested.) 20 20 21 21 || ||= 1.0 =||= 1.1||= 2.0 =|| 22 22 ||= ArcGIS =|| Result with normal CRS: OK || Result with normal CRS: !GridOffsets must dx,dy, i.e., without 0,0 || Result with normal CRS: Only scaleFactor seems to be supported. GDAL fails if the returned raster does not have the anticipated size. || 23 23 ||= !GeoServer =|| Result with normal CRS: OK, with inverted axis CRS: OK || The bounding box should contain the cell areas. Inverted CRS: !GridOrigin and !GridOffsets should not have inverted coordinate order, GDAL does not accept the returned raster but it seems ok, it just has strange !GeoTransform || Inverted CRS: subset axes need to be inverted, grid axis order should not be swapped although sequence order says so || 24 ||= !MapServer =|| Results with inverted axis CRS: OK || Results with inverted axis CRS: !GridOffsets must be abs(dx),abs(dy), i.e., without 0,0 and positive. || Results with inverted axis CRS: Grid axis labels must not be swapped; Grid otherwise ok since no coverageFunction ||24 ||= !MapServer =|| Results with inverted axis CRS: OK || Results with inverted axis CRS: !GridOffsets must be abs(dx),abs(dy), i.e., without 0,0 and positive. GridCRS coordinates should not be inverted. || Results with inverted axis CRS: Grid axis labels must not be swapped; Grid otherwise ok since no coverageFunction || 25 25 ||= Rasdaman =|| Rasdaman does not support || Rasdaman does not support || Results with inverted axis CRS: OK || 26 26
