Changes between Version 10 and Version 11 of UserDocs
- May 25, 2007, 2:11:04 PM (17 years ago)
UserDocs
v10 v11 3 3 When you create a new page please use the subwiki syntax `UserDocs/ANewWikiPage` so it will be properly nested in the TitleIndex and easy to seperate from the developer and trac system pages. If you don't like `UserDocs` being prefixed in front, use the bracket syntax of `[UserDocs/EasyToReadName Easy to read name]`, which will be displayed as ''Easy to read name'' 4 4 5 [UserDocs/GdalTranslate GdalTranslate] - enhanced docs and tips for the `gdal_translate` utility 5 == Extended documentation and tips for the GDAL and OGR end user utilities == 6 [UserDocs/GdalTranslate GdalTranslate]- for converting rasters to other formats [[BR]] 7 [UserDocs/OgrInfo OgrInfo] - report information on vector files (feature type, projection, schema, etc.)
