Changes between Version 5 and Version 6 of UserDocs/GdalWarp
- 02/29/08 13:27:49 (5 years ago)
UserDocs/GdalWarp
v5 v6 93 93 on 8bit data with no nodata or alpha masking in effect. 94 94 95 ----- 96 Sources: 95 Sources 97 96 * [Gdal-dev] Will increasing the RAM on a server increase the speed of gdalwarp? - http://lists.maptools.org/pipermail/gdal-dev/2007-July/013566.html 98 97 … … 103 102 So if you want to compare a true pixel-by-pixel reprojection use `-te 0` which disables this approximator entirely. 104 103 104 Source: 105 * Gdalwarp speed comparison - http://www.nabble.com/Gdalwarp-speed-comparison-td15759991.html
