Changes between Version 4 and Version 5 of TracLinks
- May 8, 2022, 3:10:44 PM (2 years ago)
TracLinks
v4 v5 4 4 [[PageOutline(2-5,Contents,pullout)]] 5 5 6 TracLinks are a fundamental feature of Trac, because they allow easy hyperlinking between the various entities in the system — such as tickets, reports, changesets, Wiki pages, milestones, and source files — from anywherewhere WikiFormatting is used.6 TracLinks are a fundamental feature of Trac, allowing easy hyperlinking between the various entities in the system — such as tickets, reports, changesets, Wiki pages, milestones, and source files — from anywhere WikiFormatting is used. 7 7 8 8 TracLinks are generally of the form '''type:id''' (where ''id'' represents the number, name or path of the item) though some frequently used kinds of items also have short-hand notations. … … 32 32 Revision log :: `r1:3`, `[1:3]` or `log:@1:3`, `log:trunk@1:3`, `[2:5/trunk]` 33 33 Diffs :: `diff:@1:3`, `diff:plugins/0.12/mercurial-plugin@9128:9953`, 34 `diff:tags/trac-0.9.2/wiki-default//tags/trac-0.9.3/wiki-default` 34 `diff:tags/trac-0.9.2/wiki-default//tags/trac-0.9.3/wiki-default` 35 35 or `diff:trunk/trac@3538//sandbox/vc-refactoring@3539` 36 Files :: `source:trunk/COPYING`, `source:/trunk/COPYING@200` (at version 200), `source:/trunk/COPYING@200#L25` (at version 200, line 25) 36 Files :: `source:trunk/COPYING`, `source:/trunk/COPYING@200` (at version 200), `source:/trunk/COPYING@200#L25` (at version 200, line 25), `source:/trunk/COPYING@200:27-30#L25` (at version 200, line 25, highlighting lines 27-30) 37 37 }}} 38 38 {{{#!td … … 40 40 Parent page :: [..] 41 41 Tickets :: #1 or ticket:1 42 Ticket comments :: comment:1:ticket:2 42 Ticket comments :: comment:1:ticket:2 43 43 Reports :: {1} or report:1 44 44 Milestones :: milestone:1.0 … … 47 47 Revision log :: r1:3, [1:3] or log:@1:3, log:trunk@1:3, [2:5/trunk] 48 48 Diffs :: diff:@1:3, diff:plugins/0.12/mercurial-plugin@9128:9953, 49 diff:tags/trac-0.9.2/wiki-default//tags/trac-0.9.3/wiki-default 49 diff:tags/trac-0.9.2/wiki-default//tags/trac-0.9.3/wiki-default 50 50 or diff:trunk/trac@3538//sandbox/vc-refactoring@3539 51 Files :: source:trunk/COPYING, source:/trunk/COPYING@200 (at version 200), source:/trunk/COPYING@200#L25 (at version 200, line 25) 51 Files :: source:trunk/COPYING, source:/trunk/COPYING@200 (at version 200), source:/trunk/COPYING@200#L25 (at version 200, line 25) source:/trunk/COPYING@200:28-31#L25 (at version 200, line 25, highlighting lines 28-31) 52 52 }}} 53 53 … … 78 78 }}} 79 79 |-------------------------------------------------------------------------------------- 80 |||| `wiki` is the default if the namespace part of a full link is omitted: || 80 |||| `wiki` is the default if the namespace part of a full link is omitted: || 81 81 {{{#!td 82 82 {{{ … … 99 99 <wiki:Strange(page@!)> 100 100 }}} 101 |-------------------------------------------------------------------------------------- 102 |||| Quoting can be used with the full notation to allow brackets in the label. || 103 {{{#!td 104 {{{ 105 [TracIni#logging-log_type-option "[logging] log_type"] 106 }}} 107 }}} 108 {{{#!td 109 [TracIni#logging-log_type-option "[logging] log_type"] 110 }}} 101 111 }}} 102 112 … … 125 135 126 136 But in practice you often won't need to add the `../` prefix to link to a sibling page. 127 For resolving the location of a wiki link, it's the target page closest in the hierarchy to the page where the link is written which will be selected. So for example, within a sub-hierarchy, a sibling page will be targeted in preference to a top level page.137 For resolving the location of a wiki link, it's the target page closest in the hierarchy to the page where the link is written which will be selected. So for example, within a sub-hierarchy, a sibling page will be targeted in preference to a top-level page. 128 138 This makes it easy to copy or move pages to a sub-hierarchy by [[WikiNewPage#renaming|renaming]] without having to adapt the links. 129 139 … … 138 148 [#Linkanchors Link anchors] or [[#Linkanchors|Link anchors]] 139 149 140 Hint: when you moveyour mouse over the title of a section, a '¶' character will be displayed. This is a link to that specific section and you can use this to copy the `#...` part inside a relative link to an anchor.150 Hint: when you hover your mouse over the title of a section, a '¶' character will be displayed. This is a link to that specific section and you can use this to copy the `#...` part inside a relative link to an anchor. 141 151 142 152 To create a link to the first or last occurrence of a term on a page, use a ''pseudo anchor'' starting with '#/' or '#?': … … 182 192 This can be seen as a kind of InterWiki link specialized for targeting other Trac projects. 183 193 184 Any type of Trac link can be written in one Trac environment and actually refer to resources in another Trac environment. All that is required is to prefix the Trac link with the name of the other Trac environment followed by a colon. The other Trac environment must be registered on the InterTrac page. 185 186 A distinct ive advantage of InterTrac links over InterWiki links is that the shorthand form of Trac links (e.g. `{}`, `r`, `#`) can also be used. For example if T was set as an alias for Trac, links to Trac tickets can be written #T234, links to Trac changesets can be written[trac 1508].187 See InterTrac for the complete details. 194 Any type of Trac link can be written in one Trac environment and actually refer to resources in another Trac environment. All that is required is to prefix the Trac link with the name of the other Trac environment followed by a colon. The other Trac environment must be registered on the InterTrac page. 195 196 A distinct advantage of InterTrac links over InterWiki links is that the shorthand form of Trac links can also be used, such as `{}`, `r`, `#`. For example, if T was set as an alias for Trac, then links to Trac tickets can be written as #T234, and links to Trac changesets can be written as [trac 1508]. 197 See InterTrac for the complete details. 188 198 189 199 === Server-relative links … … 215 225 * !wiki:"The whitespace convention" 216 226 * !attachment:'the file.txt' or 217 * !attachment:"the file.txt" 218 * !attachment:"the file.txt:ticket:123" 227 * !attachment:"the file.txt" 228 * !attachment:"the file.txt:ticket:123" 219 229 220 230 Note that by using [trac:WikiCreole] style links, it's quite natural to write links containing spaces: … … 251 261 252 262 The link syntax for attachments is as follows: 253 * !attachment:the_file.txt creates a link to the attachment the_file.txt of the current object263 * !attachment:the_file.txt creates a link to the attachment the_file.txt of the current page 254 264 * !attachment:the_file.txt:wiki:MyPage creates a link to the attachment the_file.txt of the !MyPage wiki page 255 265 * !attachment:the_file.txt:ticket:753 creates a link to the attachment the_file.txt of the ticket 753 256 266 257 Note that the older way, putting the filename at the end, is still supported: !attachment:ticket:753:the_file.txt .267 Note that the older way, putting the filename at the end, is still supported: !attachment:ticket:753:the_file.txt, but is not recommended. 258 268 259 269 If you'd like to create a direct link to the content of the attached file instead of a link to the attachment page, simply use `raw-attachment:` instead of `attachment:`. 260 270 261 This can be useful for pointing directly to an HTML document, for example. Note that for this use case, you'd have to allow the web browser to render the content by setting `[attachment] render_unsafe_content = yes` (see TracIni#attachment-section). Caveat: only do that in environments for which you're 100% confident you can trust the people who are able to attach files, as otherwise this would openup your site to [wikipedia:Cross-site_scripting cross-site scripting] attacks.271 This can be useful for pointing directly to an HTML document, for example. Note that for this use case, you'd have to allow the web browser to render the content by setting [[TracIni#attachment-render_unsafe_content-option|"[attachment] render_unsafe_content"]] = `enabled`. Caveat: only do that in environments for which you're 100% confident you can trust the people who are able to attach files, as this opens up your site to [wikipedia:Cross-site_scripting cross-site scripting] attacks. 262 272 263 273 See also [#export:links]. … … 267 277 When you're inside a given ticket, you can simply write e.g. !comment:3 to link to the third change comment. 268 278 It is possible to link to a comment of a specific ticket from anywhere using one of the following syntax: 269 - `comment:3:ticket:123` 279 - `comment:3:ticket:123` 270 280 - `ticket:123#comment:3` (note that you can't write `#123#!comment:3`!) 271 281 It is also possible to link to the ticket's description using one of the following syntax: … … 284 294 === search: links 285 295 286 See TracSearch#Search Links296 See TracSearch#SearchTracLinks 287 297 288 298 === ticket: links … … 292 302 Besides the obvious `ticket:id` form, it is also possible to specify a list of tickets or even a range of tickets instead of the `id`. This generates a link to a custom query view containing this fixed set of tickets. 293 303 294 Example: 304 Example: 295 305 - `ticket:5000-6000` 296 306 - `ticket:1,150` … … 312 322 See WikiPageNames and [#QuotingspaceinTracLinks quoting space in TracLinks] above. It is possible to create a link to a specific page revision using the syntax WikiStart@1. 313 323 314 === Version Control relatedlinks315 316 It should be noted that multiple repository support works by creating a kind of virtual namespace for versioned files in which the toplevel folders correspond to the repository names. Therefore, in presence of multiple repositories, a ''/path'' specification in the syntax of links detailed below should start with the name of the repository. If omitted, the default repository is used. In case a toplevel folder of the default repository has the same name as a repository, the l atter "wins". One can always access such folder by fully qualifying it. The default repository can be an alias of a named repository, or conversely, it is always possible to create an alias for the default repository, ask your Trac administrator.324 === Version Control system links 325 326 It should be noted that multiple repository support works by creating a kind of virtual namespace for versioned files in which the toplevel folders correspond to the repository names. Therefore, in presence of multiple repositories, a ''/path'' specification in the syntax of links detailed below should start with the name of the repository. If omitted, the default repository is used. In case a toplevel folder of the default repository has the same name as a repository, the link directs to the latter. One can always access such folder by fully qualifying it. The default repository can be an alias of a named repository, or conversely, there may be one or more aliases for the default repository, ask your Trac administrator. 317 327 318 328 For example, `source:/trunk/COPYING` targets the path `/trunk/COPYING` in the default repository, whereas `source:/projectA/trunk/COPYING` targets the path `/trunk/COPYING` in the repository named `projectA`. This can be the same file if `'projectA'` is an alias to the default repository or if `''` (the default repository) is an alias to `'projectA'`. … … 348 358 * `export:/some/file@named-branch` - get latest revision of the specified file in `named-branch` (DVCS such as Git or Mercurial). 349 359 350 This can be very useful for displaying XML or HTML documentation with correct stylesheets and images, in case that has been checked in into the repository. Note that for this use case, you'd have to allow the web browser to render the content by setting `[browser] render_unsafe_content = yes` (see TracIni#browser-section), otherwise Trac will force the files to be downloaded as attachments for security concerns.360 This can be very useful for displaying XML or HTML documentation with correct stylesheets and images, in case that has been checked in into the repository. Note that for this use case, you'd have to allow the web browser to render the content by setting [[TracIni#browser-render_unsafe_content-option|"[browser] render_unsafe_content"]] = `enabled`, otherwise Trac will force the files to be downloaded as attachments for security concerns. 351 361 352 362 If the path is to a directory in the repository instead of a specific file, the source browser will be used to display the directory (identical to the result of `source:/some/dir`). … … 358 368 - `log:/trunk/tools` - the latest revisions in `trunk/tools` 359 369 - `log:/trunk/tools@10000` - the revisions in `trunk/tools` starting from revision 10000 360 - `log:@20788,20791:20795` - list revision 20788 and the revisions from 20791 to 20795 370 - `log:@20788,20791:20795` - list revision 20788 and the revisions from 20791 to 20795 361 371 - `log:/trunk/tools@20788,20791:20795` - list revision 20788 and the revisions from 20791 to 20795 which affect the given path 362 372 - `log:/tools@named-branch` - the revisions in `tools` starting from the latest revision in `named-branch` (DVCS such as Git or Mercurial) … … 369 379 Finally, note that in all of the above, a revision range can be written either as `x:y` or `x-y`. 370 380 371 In the presence of multiple repositories, the name of the repository should be specified as the first part of the path, e.g. `log:repos/branches` or `[20-40/repos]`. 381 ==== Multi-repository links 382 383 In the presence of multiple repositories, the name of the repository should be specified as the first part of the path: 384 - `log:repos/branch` 385 - `[20-40/repos]` 386 - `r20/repos` 372 387 373 388 ----
