Changes between Version 6 and Version 7 of TestingNotes
- 07/19/08 05:05:53 (5 years ago)
TestingNotes
v6 v7 4 4 == gdalautotest == 5 5 6 The primary means of testing is to run the [http://trac.osgeo.org/gdal/browser/trunk/ gdalautotest gdalautotest] python regression test suite. After building with either the old or new generation python bindings, and installing them (or adding them to your path from the build tree) do the following:6 The primary means of testing is to run the [http://trac.osgeo.org/gdal/browser/trunk/autotest gdalautotest] python regression test suite. After building with either the old or new generation python bindings, and installing them (or adding them to your path from the build tree) do the following: 7 7 8 8 {{{
