Changes between Version 3 and Version 4 of TestMatrix160
Show
10/30/08 08:42:50 (5 years ago)
dron
  • TestMatrix160
    v3 v4
    55 1. If you have some advises, bug workarounds, extended notes etc. don't put it here but rather create a separate Wiki page and put a link in "Notes" section.
    66 1. There are plenty of options in GDAL building with some third-party library. You can use the library from your operating system distribution, you can compile it yourself, you can get the binaries from library developers, you can use various versions of the library etc. It is not possible to cover every possible combination, so report how GDAL works with the library from your OS distro by default. If you have a reason to use 3rd party library from other source describe it in "Notes" section.
     7 1. Some information on running the autotest suite is available in the TestingNotes.
    78
    89== Platforms ==
