Changes between Version 16 and Version 17 of TestMatrix150
- Dec 8, 2007, 4:21:35 PM (16 years ago)
TestMatrix150
v16 v17 28 28 * no reports 29 29 * MacOS X (indicate version, PPC vs. Intel, normal vs. framework) 30 * no reports30 * kyngchaos, built framework PPC+Intel/32+64bit on OSX 10.5 (Leopard), tested Intel 32bit on Leopard, all formats possible on OSX (ie no win-only deps), except no Xerces support since it can't be built 64bit, and no OCI which is PPC-only. GRASS, ECW, MrSID as plugins. Can test Intel and PPC 32bit on OSX 10.4 (Tiger) later. Can only do program run tests in 64bit mode since Python doesn't run 64bits (may be able to work out something later). 31 31 * Other Unix (list OS, toolchain, CPU) 32 32 * no reports … … 42 42 * Python Unix-like / (indicate Python version, NG vs. OG, install method) 43 43 * rouault: r13274 (post-beta1), Ubuntu 7.10 i386, python 2.5, NG, install method : make install, autotests are fine 44 * kyngchaos: autotests run on OSX. Python 2.5 Leopard Intel 32bit. (Tiger test later) 44 45 * Perl Win32 45 46 * no reports … … 61 62 * no reports 62 63 * ECW 63 * no reports64 * kyngchaos: r1655 OSX - ECW library can't write 64 65 * JP2KAK 65 66 * no reports 66 67 * MrSID 67 * no reports68 * kyngchaos: OSX - MrSID libraries only available 32bit, so can't test 64bit OSX. 68 69 * ADRG 69 70 * rouault : r13274 (post-beta1), Ubuntu 7.10 i386, autotest fine, openev fine on all available operationnal datasets (all = just one ;-)) … … 97 98 * warmerdam: autotest succeeding on MacOS X (epimetheus) and i32 linux (telascience). 98 99 * rouault : r13274 (post-beta1), Ubuntu 7.10 i386, autotest fine 100 * HTTP 101 * kyngchaos: must disable DODS (GDAL_SKIP) for this to test correctly 99 102 * Other 100 103 … … 102 105 103 106 * OCI (Oracle) 104 * no reports107 * kyngchaos: OCI libraries only available for PPC OSX, I gave up on OCI long ago. 105 108 * KML 106 109 * rouault : r13274 (post-beta1), Ubuntu 7.10 i386, autotest fine … … 122 125 * no reports 123 126 * DODS 124 * no reports127 * kyngchaos: OSX - have never been able to test successfully, autotest test server never responds. 125 128 * PG (Postgres/PostGIS) 126 129 * no reports
