Changes between Version 12 and Version 13 of SupportedCompilers
- Apr 28, 2007, 2:30:43 PM (17 years ago)
SupportedCompilers
v12 v13 1 = List ofSupported Compilers =1 = Supported Compilers = 2 2 3 Please, add your environment if it's not listed below yet and you've built GDAL with it successfully. 3 This is list of '''officially''' supported [http://en.wikipedia.org/wiki/List_of_compilers compilers]: 4 5 ||'''Compiler'''||'''Vendor'''||'''Notes'''|| 6 ||[http://gcc.gnu.org/ GCC]||GNU||Including [http://www.mingw.org/ MinGW] and GCC from [http://www.cygwin.com/ Cygwin]|| 7 ||[http://msdn2.microsoft.com/en-us/visualc/default.aspx Microsoft Visual C++]||Microsoft|||| 8 ||[http://www.openwatcom.org Watcom C/C++]||Sybase|||| 9 ||[http://www.sgi.com/products/software/irix/tools/mipspro.html MIPSpro]||SGI|||| 10 11 == Tested Environments == 12 13 Please, '''add your environment''' if it's not listed below yet and you've built GDAL with it successfully. 4 14 5 15 ||'''Operating System'''||'''Architecture'''||'''Compiler version'''||'''Notes'''|| … … 21 31 ||Microsoft Windows||32-bit||gcc 3.4.2 mingw-special, binutils 2.17|||| 22 32 ||...||...||...||...|| 33 34 = Unsupported Compilers = 35 36 This is list of officially '''not supported''' compilers: 37 38 ||'''Compiler'''||'''Vendor'''|| 39 ||[http://www.codegear.com/Products/CBuilder/tabid/123/Default.aspx Borland C++ Builder]||CodeGear (Borland)|| 40 ||[http://www.turboexplorer.com/cpp Turbo C++]||Borland||
