Changes between Version 3 and Version 4 of SponsorshipSurvey
- Oct 15, 2007, 1:52:50 PM (17 years ago)
SponsorshipSurvey
v3 v4 17 17 8. Is international and localized support in GDAL/OGR important to your organization? (ie. multi-byte characters in filenames, features attributes, metadata)? (not at all important, somewhat important, very important) If so, what particular aspects are important? 18 18 19 9. Do you use GDAL/OGR in combination with other open source applications or libraries (eg. MapServer, MapGuide, GRASS) and if yes which ones. Are there any aspects of integration between GDAL/OGR and those applications or libraries that you would like to see improved?Which ones?19 9. Do you use GDAL/OGR in combination with other open source applications or libraries (eg. !MapServer, !MapGuide, GRASS, PROJ.4) and if yes which ones. Are there any aspects of integration between GDAL/OGR and those applications or libraries that you would like to see improved? Which ones? 20 20 21 21 10. Is improving the performance of GDAL/OGR important to your organization? (not at all important, somewhat important, very important) Are their particular code paths you would like to see optimized?
