Changes between Version 2 and Version 3 of SOSI
- Apr 25, 2013, 12:29:26 AM (11 years ago)
SOSI
v2 v3 48 48 [https://bitbucket.org/kartverket/fyba/src/e0a53133586261258e9333ce314ba1df0a1fb63e/releases?at=releases] 49 49 50 == Testing thedriver ==50 == Testing and using the SOSI driver == 51 51 52 52 To test if the driver is been loaded, execute the following (look for "SOSI" in the results): … … 65 65 }}} 66 66 67 Note: 68 When accessing a SOSI file, the SOSI driver writes out indices into a subfolder within the same directory where your SOSI files (.sos) are stored. Therefore you have to have write access to the directory containing your SOSI files. 67 69 68 70 == Open Tickets ==
