Changes between Initial Version and Version 1 of Release/3.0.2-News
Oct 28, 2019, 3:33:38 AM (5 years ago)
Even Rouault
3.0.2 news page
  • Release/3.0.2-News
     1= GDAL/OGR 3.0.2 Release Notes =
     3The 3.0.2 release is a bug fix release.
     5== Misc ==
     7 * Replace a few catch of bad_alloc by exception to handle the case of 32 bit trying to allocate more than 4GB of memory and thus throwing a length_error exception. Found by OSS Fuzz
     8 * Fix issues with thread_local and C++ objects that don't work well with DLL on Windows
     9 * Fix build against Poppler 0.82
     10
     11== Port ==
     12
     13 * /vsicrypt/: fix memleak in error code path
     14 * /vsitar/: accept space as end of field terminator
     15
     16== GDAL core ==
     17
     18 * fix non-neareset resampling over nodata blocks (#1941)
     19
     20== GDAL utilities ==
     21
     22 * gdalwarp: adjust nodata values, passed with -srcnodata/-dstnodata, and close to FLT_MAX to exactly it (#1724)
     23 * Python scripts: GetOutputDriverFor(): fixes error when multiple drivers found ( #1719)
     25== GDAL drivers ==
     27BAG driver:
     28 * calculate the northeast pixel corner rather than scaling the resolution, due to an incorrectly shifted northeast corner in some CARIS surveys (#1728)
     29
     30CTable2Dataset driver:
     31 * SetGeoTransform(): fix read buffer overflow from stack
     32
     33DAAS driver:
     34 * accept 4-band RGBA PNG response even when a single band is requested
     35
     36ENVI driver:
     37 * preserve 'byte order' on update (#1796)
     38
     39FITS driver:
     40 * fix memory leaks
     41
     42GTiff driver:
     43 * fix memory leak with -co APPEND_SUBDATASET=YES
     44 * ensure GDAL PROJ context is used for all libgeotiff functions (requires internal libgeotiff / libgeotiff 1.6)
     45 * make sure that GetMetadataDomainList() doesn't return EXIF when there's no EXIF metadata (https://github.com/mapbox/rasterio/pull/1740#issuecomment-526660946)
     46 * GTIFGetOGISDefn: avoid querying UOM length info when it is KvUserDefined to avoid an error to be emitted
     47 * Internal libtiff: backport security related fixes
     48
     49HDF5 and netCDF drivers:
     50 * fix crash when reading attributes of type string of variable length with NULL values
     51
     52IGNFHeightASCIIGrid driver:
     53 * fix to read RASPM2018.mnt grid
     54
     55JP2KAK driver:
     56 * fix issue with multi-threaded reads
     57
     58JP2OpenJPEG driver:
     59 * fix error logic in multi-threaded code causing memory corruption
     60 * fix reading overviews, when tiled API is used, and the dimensions of the full resolution image are not a multiple of 2^numresolutions (#1860)
     61 * fix to return the proper number of bytes read when we read more than 2 GB at once (https://github.com/uclouvain/openjpeg/issues/1151)
     62
     63JPEG driver:
     64 * fix further calls to RasterIO after reading full image at full resolution (#1947)
     65
     66MRF driver:
     67 * do not hardcode GDAL internal zlib header
     68
     69netCDF driver:
     70 * Allow "radian" value for the X/Y axis units
     71
     72PDF driver:
     73 * PDF composer from XML: fix wrong use of SetupVectorGeoreferencing()
     74 * fix nullptr dereferences on corrupted files (OSS Fuzz #16438, #16558, #16759)
     75 * fix potential heap buffer overflow (OSS Fuzz #16546)
     76 * avoid potential integer division by zero (OSS Fuzz #17129)
     78PDS4 driver:
     79 * support reading a_axis_radius and c_axis_radius (#1851)
     80
     81SAFE driver:
     82 * avoid potential use-after-free (Coverity 1404037 and 1404140)
     83
     84Terragen driver:
     85 * avoid potential use-after-free on error code path in write_header() (Coverity 1404060)
     86
     87USGSDEM driver:
     88 * avoid int overflow. Fixes OSS Fuzz #15715
     89 * fix reading FEMA generated Lidar datasets whose header is 918 bytes large
     90
     91VRT driver:
     92 * avoid erroneous pixel request do be done with KernelFilteredSource
     93
     94== OGR core ==
     95
     96 * OGRExpatRealloc(): fix double-free when size to allocate is above the default 10MB threshold. OSS Fuzz #16178 / CVE-2019-17545
     97 * OGR SQLite: do not propagate 'IS / IS NOT value' constructs to OGR SQL
     98 * OGRSimpleCurve::setNumPoints(): avoid potential int overflow on 32 bit on big values of nNewPointCount. OSS Fuzz #18092
     99 * OGRSimpleCurve::getPoints() with XYZM: fix wrong stride used for M array
     100 * OGRSimpleCurve: fix reversePoints() and addSubLineString() to take into account M dimension
     101
     102== OGR drivers ==
     103
     104CAD driver:
     105 * libopencad: CADBuffer: replace m_guard by m_nSize to avoid pointer wrap around on 32 bit platforms on corrupted files. OSS Fuzz #16388
     106
     107DGN driver:
     108 * avoid size_t overflow / illegal memory access. OSS Fuzz #16393
     109
     110GeoJSON driver:
     111 * fix update of file on Windows (https://github.com/qgis/QGIS/issues/28580)
     112 * add a OGR_GEOJSON_MAX_OBJ_SIZE configuration option to be able to parse jumbo GeoJSON Features.
     113
     114GPX driver:
     115 * fix memory leak when streaming to /vsistdout/
     116
     117LIBKML driver:
     118 * make it accept /vsigzip/foo.kml.gz files (#1743)
     119 * fix potential memory leak. (Coverity 1404148)
     120
     121MITAB driver:
     122 * Update WindowsLatin2 definition (#1571)
     123 * fix potential double-free (Coverity 1404224)
     124 * avoid potential nullptr deref (Coverity 1404174)
     125
     126PDF driver:
     127 * fix reading polygon with holes and Bezier curves (#1932)
     128 * fix reading strings with escape sequences
     129
     130PostgreSQL driver:
     131 * add support for PostgreSQL 12 (#1692)
     132 * be more restrictive when deducing non-nullability of columns in SQL result layers (#1734)
     133
     134Selafin driver:
     135 * temptative fix for stack read overflow of OSS Fuzz #18342
     136
     137S57 driver:
     138 * s57objectclasses.csv: add missing TXTDSC attribute for DRYDOC class (#1723)
     139
     140XLSX driver:
     141 * add support for .xlsm extension
     142
     143WFS3/OAPIF driver:
     144 * correctly handle user query string parameters in connection URL (#1710)
     145 * align with the final state of the OGC API - Features : Core 1.0 spec (#1878)
     146
     147== Python bindings ==
     148
     149 * add compatibility with SWIG 4.0 (#1702)
     150 * Fix swig python wheel on darwin
