10 | | GDAL: |
11 | | * SetColorTable() not supported for existing TIFF files (#2421) |
12 | | * IReadBlock failure in gdaladdo (#2486) |
13 | | * Opening large GIF files causes GDALOpen() to hang. (#2542) |
14 | | * VRTSourcedRasterBand fails if there are no sources (#2728) |
15 | | * Set projection to an existing HFA dataset as a PE string (#2731) |
16 | | * [PATCH - libtiff] JPEG compression in TIF doesn't work (#2748) |
17 | | * GRIB driver asserts (crashes) on opening this dataset (#2751) |
18 | | * georaster: In Oracle 10g generateSpatialExtent() in PL/SQL accept only one parameter (#2754) |
19 | | * gdalwarp to geotiff 1 bit mangles image (#2759) |
20 | | * gdalwarp to geotiff - TFW=YES ignored (#2760) |
21 | | * GDALOpenShared may crashes if dataset description is not the dataset filename (#2797) |
22 | | * A number of drivers implementation of Create() and CreateCopy() don't handle properly nBands == 0 (#2799) |
23 | | * bsb kap noaa (#2817) |
24 | | * gdalwarp with compression corrupts output (#2820) |
25 | | * BMP driver may crash when reading corrupted files (#2827) |
26 | | * JDEM driver leaks and may crash on corrupted dataset (#2828) |
27 | | * GXF driver doesn't validate raster dimensions (#2829) |
28 | | * GFF driver doesn't support big endian host (#2832) |
29 | | * GDALDatasetPool::~GDALDatasetPool() asserts when an underlying file cannot be opened (#2837) |
30 | | * Unable to delete colormap from HFA (#2842) |
31 | | * Overview is AUX (#2854) |
32 | | * AIGRID driver cannot read RAT on Windows (#2865) |
33 | | * Projection Warning only printed for debug mode (ISIS 2/3, PDS) (#2873) |
34 | | * Crash when serializing VRTDerivedRasterBand without pixel func defined (#2877) |
35 | | * GRIB driver crashes with large datasets (#2887) |
36 | | * Closing a dataset opened with GDALOpenShared in another thread causes later corruption (#2897) |
37 | | * ERS shows 8 bit signed integer datasets as unsigned integer. (#2902) |
38 | | * Overviews cannot be built for CIT or COT (#2904) |
39 | | * ERS file pointing to an ECW file is not opening when a full path name is not specified (#2906) |
40 | | * ERS file pointing to an ECW file is not opening when a full path name is not specified (#2908) |
41 | | * Reposition all NITF image and annotation segments relative to the base (0) segment (#2912) |
42 | | * Building RRD overviews using AVERAGE_BIT2GRAYSCALE results in wrong value (#2914) |
43 | | * GeoRaster: NBIT need swapping (#2917) |
44 | | * GeoRaster: Some combinations of Interleaving and bands per blocks fail (#2923) |
45 | | * GeoRaster: Error compressing (DEFLATE) incomplete blocks (#2924) |
46 | | * Memory overwrite while zooming an ECW image (#2934) |
47 | | * Georaster - Pyramid Levels mismatch (#2946) |
48 | | * Keyword causing format unrecognized (PDS) (#2956) |
49 | | * 11 bit JPEG2000 compressed NITIF shows as 8 bit (#2964) |
50 | | * GeoRaster: Non georeferenced images wrongly reported (#2967) |
| 10 | General: |
| 11 | * Add cast to (unsigned char) in all isspace() calls (#1681) |
| 12 | |
| 13 | OGR Core: |
| 14 | * (core) Fix crash in OGRStyleTable::AddStyle (#2810, #2531) |
| 15 | * (core) crash in OGRLinearRing::get_Area() (#2792) |
| 16 | * (core) GetFieldAsString() fails (aborts) on Ubuntu 8.10 (#2896) |
| 17 | * (core) Issues related to wildcard expansion in SQL result layer (#2788) |
| 18 | * (core) Generic SQL doesn't support feature styles (#2808) |
| 19 | * (BNA) BNA inner ring contains only duplication of first point (#2985) |
| 20 | * (Geoconcept) out of bound access in geoconcept.c (#2918) |
| 21 | * (GeoJSON) Handle "link" and "name" srs members for GeoJSON (#2665) |
| 22 | * (GeoJSON) Memory leak in GeoJSON driver for spatial reference of geometry of feature (#2863) |
| 23 | * (GML) GML read failure on some Unicode strings for GDAL 1.6+ (#2948) |
| 24 | * (GML) OGRGMLLayer::GetFeatureCount() returns -1 if there's a .XSD file available (#2969) |
| 25 | * (GML) OGR support GML 3.1.1 level 0 (#2932) |
| 26 | * (GML) GDAL thinks string field is an integer field in GML layer (#2493) |
| 27 | * (GPX) OGR GPX driver creates duplicate field names in shapefile (#2966) |
| 28 | * (KML) KML Driver - Placemark with Multigeometry Polygons fails (#1853) |
| 29 | * (KML) KML: Encoding issue and mixed container (#2181) |
| 30 | * (KML) KML: Documents with multiple geometry types are not supported (#1803) |
| 31 | * (OCI) OCI varchar2(4000) (#2876) |
| 32 | * (PG) Postgresql field count wrong (#962) |
| 33 | * (PG) postgres driver failes to create geometry index if layer name starts with a number (#2945) |
| 34 | * (SDE) SDE connection failed message non descriptive (#1444) |
| 35 | * (Shape) .dbf files; inconsistencies with date formats (#2746) |
| 36 | * (VRT) OGR VRT driver may crash when there are missing elements in the XML definition (#2952) |
| 37 | |
| 38 | OGR Spatial References: |
| 39 | * PROJCS with AXIS considered invalid (#2739) |
| 40 | * Wrong name for SRS_PT_LAMBERT_CONFORMAL_CONIC_2SP_BELGIUM (#2763) |
| 41 | * IsSame results in false positive for LOCAL_CS (#2849) |
| 42 | * ERMapper projection lookup problem (#2819) |
| 43 | |
| 44 | Documentation: |
| 45 | * gdalwarp man page not generated in GDAL 1.6.0 (#2742) |
| 46 | * some bogus part in gdal_contour manual (#2790) |
| 47 | |
| 48 | Utilities: |
| 49 | * Make gdalbuildvrt compiled by default in 1.6.1 (#2987) |
| 50 | * Python utililities should support command-line wildcards (#2783) |
| 51 | * gdal_contour segfaults when no output specified (#2789) |
| 52 | * gdal_contour: -3d option doesn't work just after -fl option (#2793) |
| 53 | * gdal_contour segfaults if wrong band number is specified (#2794) |
| 54 | * gdal_vrtmerge.py -separate doesn't work (#2836) |
| 55 | * gdalwarp cblend option does not work (#2733) |
| 56 | * gdalwarp ignores cutline when -tr specified (#2847) |
| 57 | * gdalwarp cutline off source problems (#2853) |
| 58 | * multi-part cutlines not supported (#2984) |
70 | | OGR: |
71 | | * Postgresql field count wrong (#962) |
72 | | * SDE connection failed message non descriptive (#1444) |
73 | | * KML Driver - Placemark with Multigeometry Polygons fails (#1853) |
74 | | * KML: Encoding issue and mixed container (#2181) |
75 | | * Handle "link" and "name" srs members for GeoJSON (#2665) |
76 | | * Issues related to wildcard expansion in SQL result layer (#2788) |
77 | | * Generic SQL doesn't support feature styles (#2808) |
78 | | * OCI varchar2(4000) (#2876) |
79 | | * OGR support GML 3.1.1 level 0 (#2932) |
80 | | * postgres driver failes to create geometry index if layer name starts with a number (#2945) |
81 | | * GML read failure for GDAL 1.6+ (#2948) |
82 | | * OGR GPX driver creates duplicate field names in shapefile (#2966) |
83 | | * OGRGMLLayer::GetFeatureCount() returns -1 if there's a .XSD file available (#2969) |
84 | | * BNA inner ring contains only duplication of first point (#2985) |
| 70 | * (core) Building RRD overviews using AVERAGE_BIT2GRAYSCALE results in wrong value (#2914) |
| 71 | * (core) Closing a dataset opened with GDALOpenShared in another thread causes later corruption (#2897) |
| 72 | * (core) GDAL gcore not robust enough to invalid raster block dimensions (#2822) |
| 73 | * (core) GDALDatasetPool::~GDALDatasetPool() asserts when an underlying file cannot be opened (#2837) |
| 74 | * (core) GDALOpenShared may crashes if dataset description is not the dataset filename (#2797) |
| 75 | * (core) Overview is AUX (#2854) |
| 76 | * (core) GDALVersionInfo(NULL) segfaults (#2826) |
86 | | General: |
87 | | * Add cast to (unsigned char) in all isspace() calls (#1681) |
88 | | * Wrong name for SRS_PT_LAMBERT_CONFORMAL_CONIC_2SP_BELGIUM (#2763) |
89 | | * gdal_contour segfaults when no output specified (#2789) |
90 | | * GDAL gcore not robust enough to invalid raster block dimensions (#2822) |
91 | | * HDF4: Mixing Windows driver with subdataset ID (#2823) |
92 | | * GTiffRasterBand::IReadBlock() is terrible slow for big number of bands and pixel interleaving (#2838) |
93 | | * GDAL ECW driver requires to define _WIN32_WINNT=0x0500 with MSVC2008 (#2850) |
94 | | * Memory leak in GeoJSON driver for spatial reference of geometry of feature (#2863) |
95 | | * BSBDataset::open() function may consider a non-BSB file as a BSB file (#2881) |
96 | | * out of bound access in geoconcept.c (#2918) |
97 | | * ScanJPEGBlocks() finds too many "Start of Image" markers (#2927) |
98 | | * OGR VRT driver may crash when there are missing elements in the XML definition (#2952) |
| 78 | * (AIGRID) AIGRID driver cannot read RAT on Windows (#2865) |
| 79 | * (BMP) BMP driver may crash when reading corrupted files (#2827) |
| 80 | * (BSB) bsb kap noaa (#2817) |
| 81 | * (BSB) BSBDataset::open() function may consider a non-BSB file as a BSB file (#2881) |
| 82 | * (BSB) Problem with gcps count in BSB Driver (#2777) |
| 83 | * (BSB) Failure reading BSB image (#2782) |
| 84 | * (DOQ2) Potential stack buffer overflow in DOQ2 metadata reading (#2835) |
| 85 | * (DTED) Buffer overflow in DTEDCreateCopy (#2824) |
| 86 | * (DTED) DTED driver cannot read any more files with VOL or HDR (#2951) |
| 87 | * (ECW) GDAL ECW driver requires to define _WIN32_WINNT=0x0500 with MSVC2008 (#2850) |
| 88 | * (ECW) Memory overwrite while zooming an ECW image (#2934) |
| 89 | * (ENVI) ENVI importer crashes when attempting to open an ENVI signature file. (#2778) |
| 90 | * (ERS) ERS file pointing to an ECW file is not opening when a full path name is not specified (#2908) |
| 91 | * (ERS) ERS shows 8 bit signed integer datasets as unsigned integer. (#2902) |
| 92 | * (GeoRaster) Georaster - Pyramid Levels mismatch (#2946) |
| 93 | * (GeoRaster) GeoRaster: Error compressing (DEFLATE) incomplete blocks (#2924) |
| 94 | * (GeoRaster) georaster: In Oracle 10g generateSpatialExtent() in PL/SQL accept only one parameter (#2754) |
| 95 | * (GeoRaster) GeoRaster: NBIT need swapping (#2917) |
| 96 | * (GeoRaster) GeoRaster: Non georeferenced images wrongly reported (#2967) |
| 97 | * (GeoRaster) GeoRaster: Some combinations of Interleaving and bands per blocks fail (#2923) |
| 98 | * (GFF) GFF driver doesn't support big endian host (#2832) |
| 99 | * (GIF) Opening large GIF files causes GDALOpen() to hang. (#2542) |
| 100 | * (GRIB) GRIB driver asserts (crashes) on opening this dataset (#2751) |
| 101 | * (GRIB) GRIB driver crashes with large datasets (#2887) |
| 102 | * (GTiff) gdalwarp to geotiff - TFW=YES ignored (#2760) |
| 103 | * (GTiff) gdalwarp to geotiff 1 bit mangles image (#2759) |
| 104 | * (GTiff) gdalwarp with compression corrupts output (#2820) - Note: regression that appeared after 1.6.0 release |
| 105 | * (GTiff) GTiffRasterBand::IReadBlock() is terrible slow for big number of bands and pixel interleaving (#2838) |
| 106 | * (GTiff - libtiff) JPEG compression in TIF doesn't work (#2748) |
| 107 | * (GTiff) SetColorTable() not supported for existing TIFF files (#2421) |
| 108 | * (GTiff - libgeotiff) avoid needlessly deaccessing all csv files (#2957) |
| 109 | * (GXF) GXF driver doesn't validate raster dimensions (#2829) |
| 110 | * (HDF4) HDF4: Mixing Windows driver with subdataset ID (#2823) |
| 111 | * (HDF5) HDF5 driver easily confused about datatypes (#2941) |
| 112 | * (HDF5) Wrong initial value for nGCPCount in HDF5 sub-datasets (#2774) |
| 113 | * (HFA) Set projection to an existing HFA dataset as a PE string (#2731) |
| 114 | * (HFA) Unable to delete colormap from HFA (#2842) |
| 115 | * (INGR) Overviews cannot be built for CIT or COT (#2904) |
| 116 | * (ISIS, PDS) Projection Warning only printed for debug mode (ISIS 2/3, PDS) (#2873) |
| 117 | * (JDEM) JDEM driver leaks and may crash on corrupted dataset (#2828) |
| 118 | * (NITF) 11 bit JPEG2000 compressed NITF shows as 8 bit (#2964) |
| 119 | * (NITF) Reposition all NITF image and annotation segments relative to the base (0) segment (#2912) |
| 120 | * (NITF) ScanJPEGBlocks() finds too many "Start of Image" markers (#2927) |
| 121 | * (PDS) Keyword causing format unrecognized (PDS) (#2956) |
| 122 | * (SGI) Corrupted SGI images can cause crashes (#2803) |
| 123 | * (VRT) Crash when serializing VRTDerivedRasterBand without pixel func defined (#2877) |
| 124 | * (VRT) VRTSourcedRasterBand fails if there are no sources (#2728) |
| 125 | * (VRT) Blocks of data missing when warping cascaded vrt (#2867) |
