| 1 | Note!!! This page is a preview of the notes for the 1.6.1 release. 1.6.1 has not yet been officially released. |
| 2 | |
| 3 | default: |
| 4 | * Add cast to (unsigned char) in all isspace() calls (#1681) |
| 5 | * Wrong name for SRS_PT_LAMBERT_CONFORMAL_CONIC_2SP_BELGIUM (#2763) |
| 6 | * gdal_contour segfaults when no output specified (#2789) |
| 7 | * GDAL gcore not robust enough to invalid raster block dimensions (#2822) |
| 8 | * HDF4: Mixing Windows driver with subdataset ID (#2823) |
| 9 | * GTiffRasterBand::IReadBlock() is terrible slow for big number of bands and pixel interleaving (#2838) |
| 10 | * GDAL ECW driver requires to define _WIN32_WINNT=0x0500 with MSVC2008 (#2850) |
| 11 | * Memory leak in GeoJSON driver for spatial reference of geometry of feature (#2863) |
| 12 | * BSBDataset::open() function may consider a non-BSB file as a BSB file (#2881) |
| 13 | * out of bound access in geoconcept.c (#2918) |
| 14 | * ScanJPEGBlocks() finds too many "Start of Image" markers (#2927) |
| 15 | * OGR VRT driver may crash when there are missing elements in the XML definition (#2952) |
| 16 | |
| 17 | RubyBindings: |
| 18 | * swig 1.3.39 breaks nearly all swig bindings (java, python, ruby) (#2954) |
| 19 | |
| 20 | OGR_SF: |
| 21 | * Postgresql field count wrong (#962) |
| 22 | * SDE connection failed message non descriptive (#1444) |
| 23 | * KML Driver - Placemark with Multigeometry Polygons fails (#1853) |
| 24 | * KML: Encoding issue and mixed container (#2181) |
| 25 | * Handle "link" and "name" srs members for GeoJSON (#2665) |
| 26 | * Issues related to wildcard expansion in SQL result layer (#2788) |
| 27 | * Generic SQL doesn't support feature styles (#2808) |
| 28 | * OCI varchar2(4000) (#2876) |
| 29 | * OGR support GML 3.1.1 level 0 (#2932) |
| 30 | * postgres driver failes to create geometry index if layer name starts with a number (#2945) |
| 31 | * GML read failure for GDAL 1.6+ (#2948) |
| 32 | * OGR GPX driver creates duplicate field names in shapefile (#2966) |
| 33 | * OGRGMLLayer::GetFeatureCount() returns -1 if there's a .XSD file available (#2969) |
| 34 | * BNA inner ring contains only duplication of first point (#2985) |
| 35 | |
| 36 | OGR_SRS: |
| 37 | * KML: Documents with multiple geometry types are not supported (#1803) |
| 38 | * PROJCS with AXIS considered invalid (#2739) |
| 39 | * .dbf files; inconsistencies with date formats (#2746) |
| 40 | * IsSame results in false positive for LOCAL_CS (#2849) |
| 41 | |
| 42 | Docs: |
| 43 | * gdalwarp man page not generated in GDAL 1.6.0 (#2742) |
| 44 | * some bogus part in gdal_contour manual (#2790) |
| 45 | |
| 46 | PythonBindings: |
| 47 | * Python callbacks only support functions, not any callable (#2743) |
| 48 | * Broken python bindings for TransformCoordinates method of osr.CoordinateTransformation (#2764) |
| 49 | * GetFieldAsDate call in python bindings should be GetFieldAsDateTime (#2765) |
| 50 | * GetFieldAsStringList c# and Python wraper (#2839) |
| 51 | * python typemaps for OBJECT_LIST_INPUT(GDALRasterBandShadow) is broken (#2872) |
| 52 | |
| 53 | Utilities: |
| 54 | * gdalwarp cblend option does not work (#2733) |
| 55 | * Python utililities should support command-line wildcards (#2783) |
| 56 | * gdal_contour: -3d option doesn't work just after -fl option (#2793) |
| 57 | * gdal_contour segfaults if wrong band number is specified (#2794) |
| 58 | * gdal_vrtmerge.py -separate doesn't work (#2836) |
| 59 | * gdalwarp ignores cutline when -tr specified (#2847) |
| 60 | * gdalwarp cutline off source problems (#2853) |
| 61 | * multi-part cutlines not supported (#2984) |
| 62 | |
| 63 | CSharpBindings: |
| 64 | * C# Vista 64-bit OSGeo.OGR.Datasource.CreateLayer freezing (#2173) |
| 65 | * Support MSVC2008 builds with the csharp interface (#2862) |
| 66 | * Problems to compile swigged GDAL for C# on 64 bit machine (#2928) |
| 67 | * Change the dll mapping rules to support the recent MONO versions (#2961) |
| 68 | |
| 69 | Algorithms: |
| 70 | * NODATA missing in blank area when warping vrt file with expanded RGB into vrt (#2724) |
| 71 | * Cutline with blend gives wrong results inside cut polygon (#2735) |
| 72 | * Cutline with blend don't blend correctly for some pixel rows (#2740) |
| 73 | * typo in name GDAL_CG_Create in contour.cpp (#2795) |
| 74 | * Lanczos and CubicSpline resampler buffer error on 2x2 images (#2960) |
| 75 | |
| 76 | GDAL_Raster: |
| 77 | * SetColorTable() not supported for existing TIFF files (#2421) |
| 78 | * IReadBlock failure in gdaladdo (#2486) |
| 79 | * Opening large GIF files causes GDALOpen() to hang. (#2542) |
| 80 | * VRTSourcedRasterBand fails if there are no sources (#2728) |
| 81 | * Set projection to an existing HFA dataset as a PE string (#2731) |
| 82 | * [PATCH - libtiff] JPEG compression in TIF doesn't work (#2748) |
| 83 | * GRIB driver asserts (crashes) on opening this dataset (#2751) |
| 84 | * georaster: In Oracle 10g generateSpatialExtent() in PL/SQL accept only one parameter (#2754) |
| 85 | * gdalwarp to geotiff 1 bit mangles image (#2759) |
| 86 | * gdalwarp to geotiff - TFW=YES ignored (#2760) |
| 87 | * GDALOpenShared may crashes if dataset description is not the dataset filename (#2797) |
| 88 | * A number of drivers implementation of Create() and CreateCopy() don't handle properly nBands == 0 (#2799) |
| 89 | * bsb kap noaa (#2817) |
| 90 | * gdalwarp with compression corrupts output (#2820) |
| 91 | * BMP driver may crash when reading corrupted files (#2827) |
| 92 | * JDEM driver leaks and may crash on corrupted dataset (#2828) |
| 93 | * GXF driver doesn't validate raster dimensions (#2829) |
| 94 | * GFF driver doesn't support big endian host (#2832) |
| 95 | * GDALDatasetPool::~GDALDatasetPool() asserts when an underlying file cannot be opened (#2837) |
| 96 | * Unable to delete colormap from HFA (#2842) |
| 97 | * Overview is AUX (#2854) |
| 98 | * AIGRID driver cannot read RAT on Windows (#2865) |
| 99 | * Projection Warning only printed for debug mode (ISIS 2/3, PDS) (#2873) |
| 100 | * Crash when serializing VRTDerivedRasterBand without pixel func defined (#2877) |
| 101 | * GRIB driver crashes with large datasets (#2887) |
| 102 | * Closing a dataset opened with GDALOpenShared in another thread causes later corruption (#2897) |
| 103 | * ERS shows 8 bit signed integer datasets as unsigned integer. (#2902) |
| 104 | * Overviews cannot be built for CIT or COT (#2904) |
| 105 | * ERS file pointing to an ECW file is not opening when a full path name is not specified (#2906) |
| 106 | * ERS file pointing to an ECW file is not opening when a full path name is not specified (#2908) |
| 107 | * Reposition all NITF image and annotation segments relative to the base (0) segment (#2912) |
| 108 | * Building RRD overviews using AVERAGE_BIT2GRAYSCALE results in wrong value (#2914) |
| 109 | * GeoRaster: NBIT need swapping (#2917) |
| 110 | * GeoRaster: Some combinations of Interleaving and bands per blocks fail (#2923) |
| 111 | * GeoRaster: Error compressing (DEFLATE) incomplete blocks (#2924) |
| 112 | * Memory overwrite while zooming an ECW image (#2934) |
| 113 | * Georaster - Pyramid Levels mismatch (#2946) |
| 114 | * Keyword causing format unrecognized (PDS) (#2956) |
| 115 | * 11 bit JPEG2000 compressed NITIF shows as 8 bit (#2964) |
| 116 | * GeoRaster: Non georeferenced images wrongly reported (#2967) |
| 117 | |
| 118 | ConfigBuild: |
| 119 | * OGR_ENABLED not properly defined in win32 builds (#2784) |
| 120 | * mysql compile error with GCC 4.3.2: error: macro "min" passed 3 arguments, but takes just 2 (#2972) |
| 121 | |
| 122 | SWIG (all bindings): |
| 123 | * Need to expose ImportFromMICoordSys/ExportToMICoordSys to the SWIG interface (#2722) |
| 124 | * Invalid inheritance in SWIG definition of GDALColorTableShadow and GDALRasterAttributeTableShadow (#2874) |
