| 1 | = GDAL/OGR 1.4.5 - Overview of Changes = |
| 2 | |
| 3 | The GDAL 1.4.5 release is a stable release, and contains the following bug fixes. It is anticipated that GDAL 1.4.5 will be the last release produced from the 1.4 stable branch. |
| 4 | |
| 5 | == GDAL == |
| 6 | |
| 7 | * Fix memory leak of saved histograms (#2226) |
| 8 | * Preliminary GMLJP2 axis orientation workaround (#2131) |
| 9 | * Remove spurious printf() in GDALOpen() (#2166) |
| 10 | |
| 11 | MRSID Driver: |
| 12 | * Fix windowing problem with large files (#2689) |
| 13 | |
| 14 | NITF Driver: |
| 15 | * Improve georeferencing over dateline handling (#2135) |
| 16 | |
| 17 | GeoTIFF Driver: |
| 18 | * Fix creation options XML for parsability (#2322) |
| 19 | |
| 20 | PAux Driver: |
| 21 | * Permit alterate spelling of AuxiliaryTarget (#2219) |
| 22 | |
| 23 | NetCDF Driver: |
| 24 | * Handle very large attributes properly (#2196) |
| 25 | |
| 26 | PNM Driver: |
| 27 | * Fix problems identifying PNM files and overflow with corrupt files (#2190) |
| 28 | |
| 29 | AAIGRID Driver: |
| 30 | * Fix georeferencing computation in yllcorner case (#1794) |
| 31 | |
| 32 | HFA (Imagine) Driver: |
| 33 | * Fix creation of duplicate table nodes in tree (#2043) |
| 34 | |
| 35 | == OGR == |
| 36 | |
| 37 | GML Driver: |
| 38 | * Fix potential buffer overflow (#2708) |
| 39 | |
| 40 | Postgres/PostGIS Driver: |
| 41 | * Fix buffer overflow (#2303) |
| 42 | * Fix improper reporting of tables with no primary key as having a multi column primary key (#2082) |
| 43 | |
| 44 | DGN Driver: |
| 45 | * Fixes with color computation (#2035) |
| 46 | |
| 47 | == Other == |
| 48 | |
| 49 | * Fix error code detection when opening large files on Solaris (#2437) |
| 50 | * Serious fixes for Thin Plate Spline warper (#2300, #2301) |
