Changes between Version 9 and Version 10 of Release/1.4.3-News
- Oct 27, 2007, 9:27:57 PM (16 years ago)
Release/1.4.3-News
v9 v10 16 16 * Fix in calculation of yllcorner value. #1794 17 17 18 ECW Driver: 19 * Fix memory leak in ECWDataset::IRasterIO() function. #1922 20 18 21 GeoTIFF Driver: 19 * Upgraded internal libtiff to libtiff 4.x with a few patches from HEAD 22 * Upgraded internal libtiff to libtiff 4.x with a few patches from HEAD. #1920 20 23 * Fix handling of partial bottom tiles/strips. #1179 21 24 * Fix issue with mixed Lambert_Conformal_Conic_1SP and Lambert_Conformal_Conic_2SP. #1315 22 * Fix edissue with mixed names of WGS72 and WGS84 in libgeotiff code. #171525 * Fix issue with mixed names of WGS72 and WGS84 in libgeotiff code. #1715 23 26 * Improved detection of already computed overview levels. #1722 24 * Fix edmemory failures with allocating 64K entry color tables on stack. #173627 * Fix memory failures with allocating 64K entry color tables on stack. #1736 25 28 * Fix zero value issue in building pixel interleaved GeoTIFF files. #1738 26 29 … … 32 35 33 36 HFA Driver: 34 * Fix edbuilding overviews on an Imagine-created HFA file. #110937 * Fix building overviews on an Imagine-created HFA file. #1109 35 38 * Made reading variations aux.xml files more bulletproof. #1691 36 * Fix edcalculation of min/max statistics for Erdas Imagine datasets. #170237 * Fix edband value rounding issue in palletized Imagine rasters. #173239 * Fix calculation of min/max statistics for Erdas Imagine datasets. #1702 40 * Fix band value rounding issue in palletized Imagine rasters. #1732 38 41 * Ensure .ige and .rrd get cleaned up when creating new files. #1784 39 42 * Added missing bytes swapping when opening spill files. #1841 … … 54 57 55 58 Warper: 59 * Fixed Cubic Spline and Lanczos interpolators. #1610 60 * Fix in geolocation support. #1919 56 61 57 * Fixed Cubic Spline and Lanczos interpolators. #161058 62 59 63 == OGR == 60 64 61 65 VRT Driver: 62 * Fix edcopying of virtual dataset with empty filename. #174966 * Fix copying of virtual dataset with empty filename. #1749 63 67 64 68 == Other ==
