Changes between Initial Version and Version 1 of Release/1.11.5-News
Jul 1, 2016, 2:07:27 AM (8 years ago)
Even Rouault
1.11.5 news
  • Release/1.11.5-News
     1= GDAL/OGR 1.11.5 Release Notes =
     3The 1.11.5 release is a bug fix release.
     5== Build ==
     6 * Windows: update mrsid driver build to find MrSID 9.5 dll
     8== Port ==
     9 * Export VSICreateCachedFile() as CPL_DLL so as to enable building JP2KAK as a plugin (https://github.com/OSGeo/gdal/pull/126)
     10
     11== GDAL algorithms ==
     12 * GDALWarpOperation::CreateKernelMask(): fix potential 32 bit integer overflow when using warp memory value > 2GB (#6448)
     13
     14== GDAL Core ==
     15 * GDALLoadRPCFile(): load .rpc files from Ikonos products that have extra end-of-line character (#6341)
     16
     17== Utilities ==
     18 * gdal_translate: fix random behaviour when -scale is used without source bounds (#6455)
     19 * gdalbuildvrt: accept nan as value for -srcnodata and -vrtnodata (#6495)
     20
     21== GDAL drivers ==
     23GTiff driver:
     24 * Internal libtiff: fix 1.11 regression that prevents from reading one-strip files that have no StripByteCounts tag (#6490)
     25
     26netCDF driver:
     27 * do not crash on NC4 unsigned short attributes (#6337)
     28
     29PostgisRaster driver:
     30 * fix potential crash when one tile has a lower number of bands than the max of the table (fixes #6267)
     31
     32== OGRSpatialReference ==
     33 * importFromESRI(): fix import of multi line MERCATOR SRS (#6523)
     34
     35== OGR drivers ==
     36
     37Driver removed:
     38 * Google Maps Engine (GME)  (#6261)
     39
     40GeoJSON driver:
     41 * do not 'promote' a null field to OFTString type if it had another type before (#6351)
     42 * ESRI Json reader: do not set field width of 2147483647 (#6529)
     43
     44GPKG driver:
     45 * fix crash on layers with curve geometries (#6558)
     46
     47KML driver:
     48 * fix crash on KML files without content but with nested folders (#6486)
     49
     50LIBKML driver:
     51 * fix crash when reading <gx:TimeStamp> or <gx:TimeSpan> elements (#6518)
     52
     53MITAB driver:
     54 * limit (width, precision) of numeric fields on creation to (20,16) for compatibility with MapInfo (#6392)
     56OpenFileGDB driver:
     57 * transcode UTF-16 strings found in column names, alias, etc... to UTF-8 (instead of using only their ASCII byte) (#6544)
     58
     59OSM driver:
     60 * do not override 'our' osm_id (the node, way or relation id) with a tag named 'osm_id' (#6347)
     61
     62PG/PGDump drivers:
     63 * in copy mode (the default on layer creation), do not truncate the concatenated string list to the field width (#6356)
     64
     65SQLite driver:
     66 * fix crash on Unix systems with SQLite >= 3.10.0 when xCurrentTimeInt function is called (#6360)
     67
     68VFK driver:
     69 * recreate DB automatically when it's outdated (#6511)
     70
     71WFS driver:
     72 * invalidate underlying layer when SetIgnoredFields() is called (QGIS #15112)
     73
     74XLSX driver:
     75 * fix reading sheets with more than > 26 columns and 'holes' (#6363)
