Changes between Version 48 and Version 49 of NetCDF_exportUpdateChanges
- Oct 17, 2011, 9:39:40 PM (13 years ago)
v48 v49 94 94 A thorough analysis of the CF-1.5 map projections supported (see again [[http://cf-pcmdi.llnl.gov/documents/cf-conventions/1.5/apf.html CF-1.5 App F]]) showed that the mapping of OGC WKT projection parameter names to CF-1.5 equivalents needed to be done per-projection. Whereas, the existing code tried to use a single global mapping of WKT attribute names to CF-1 for use in exporting. 95 95 96 To overcome this issue we have defined per-projection mappings of OGC WKT parameter names to CF-1.5 equivalents using simple data structures, and re-written the NetCDF driver export code (in the CreateCopy() function) to reference these mappings when saving a map-projected raster. 97 98 Th is was tested for all projections listed as part of CF-1.5 by translating input files in another format (eg GeoTIFF) into NetCDF, and then ensuring the resulting files were CF-compliant and could be opened as gridded data by the NetCDF Java API.96 To overcome this issue we have defined per-projection mappings of OGC WKT parameter names to CF-1.5 equivalents using simple data structures, and re-written the NetCDF driver export code (in the CreateCopy() function) to reference these mappings when saving a map-projected raster. This approach is similar to that used for other drivers such as HFA and when exporting to ESRI PS strings. 97 98 The updated code's projection capabilities was tested for all projections listed as part of CF-1.5 by translating input files in another format (eg GeoTIFF) into NetCDF, and then ensuring the resulting files were CF-compliant and could be opened as gridded data by the NetCDF Java API. 99 99 100 100 We also tested these files could have their projections correctly re-imported back into GDAL :- and in the process updated the NetCDF driver's projection import code (in !SetProjection()) as well. 101 101 102 102 '''Note''': while we've tested the updated driver has much better coverage of CF-1.5 projection parameter handling than previously, there are still certain CF-1.5 projection unusual cases that are proving challenging to confirm an OGC WKT equivalent. We have documented this list at NetCDF_ProjectionTestingStatus, and welcome advice/testing on the remaining challenges here. 103 103 104 104 ==== 3.2) When exporting to NetCDF map projections via GDAL, save projection coordinate variables. Optionally, also save lat and lon mapping variables. ==== … … 232 232 == Appendices/Links == 233 233 234 TODO - links to Wiki page with status of projection-handling by driver in development. Will be useful to point people to this, if interested to help with testing. 234 * wiki:NetCDF_ProjectionTestingStatus: page with information on tested capabilities to export from/to CF-1.5 projections. 235 * wiki:NetCDF_Improvements: community planning page for consolidating NetCDF driver upgrade suggestions that preceded the specific work described here.
