Changes between Version 19 and Version 20 of NetCDF_exportUpdateChanges
- Oct 10, 2011, 6:15:29 PM (13 years ago)
v19 v20 39 39 === Change to a default south-up orientation for NetCDF data === 40 40 41 '''Related tix''': #4251[[BR]]41 '''Related fix''': #4251[[BR]] 42 42 43 43 '''New -co options''': No … … 57 57 === Continue saving NetCDF custom attribute tags by default, but add option not to save === 58 58 59 '''Related tix''': N/A [[BR]]59 '''Related fix''': N/A [[BR]] 60 60 '''New -co options''': -co WRITE_GDAL_TAGS (yes/no, defaults to yes)[[BR]] 61 61 '''Has back-compat impact?''': No … … 83 83 === Add saving of Datum reference Ellipsoid parameters in CF-1 compliant format, in addition to within GDAL's WKT === 84 84 85 '''Related tix''': #2893 [[BR]]85 '''Related fix''': #2893 [[BR]] 86 86 '''New -co options''': No, though related to the new proposed WRITE_GDAL_TAGS option above. 87 87 … … 108 108 === When exporting to NetCDF map projections via GDAL, save projection coordinate variables. Optionally, also save lat and lon mapping variables. === 109 109 110 '''Related tix''': #2893 [[BR]]110 '''Related fix''': #2893 [[BR]] 111 111 '''New -co options''': 112 112 * WRITE_LONLAT=YES/NO/IFNEEDED (default: YES for geographic, IFNEEDED for projected) ->Note, this not implemented yet … … 134 134 135 135 136 === Add support for different netcdf file types and compression === 137 138 '''Related fix''': N/A [[BR]] 139 '''New -co options''': 140 * FILETYPE=NC/NC2/NC4 141 * COMPRESS=NONE/DEFLATE/PACKED (default: NONE) 142 * ZLEVEL=[1-9] (default: 1) 143 144 '''Has back-compat impact?''': NC2 and NC4 filetypes, as well as DEFLATE and PACKED compression may not be supported by older netcdf installations and GDAL versions 145 146 '''Change''': 147 TBD 148 136 149 == Compatibility Issues == 137 150
