Changes between Version 10 and Version 11 of NetCDF_ProjectionTestingStatus
Show
10/18/11 15:46:23 (19 months ago)
pds
  • NetCDF_ProjectionTestingStatus
    v10 v11
    99The shorthand projection names listed below correspond to their names in the source files and hopefully are fairly self-explanatory - they've been listed in the same order as that shown on the CF-1.5 appendix page.
    1010
    11 '''Note''': the current import capability has been tested to be the inverse of the export capability. We would appreciate any help in obtaining valid test files for each of these projections. If and when we are able to test capability to import NetCDF variants that don't have a direct CF-1 equivalent, we should add a supplementary table.
     11'''Note''': the current import capability has been tested to be the inverse of the export capability. We would appreciate any help in obtaining valid test files for each of these projections. If and when we are able to test capability to import NetCDF CF-1.5 variants that don't have a direct OGC WKT equivalent, we should add a supplementary table.
    1212
    1313||'''Projection'''||'''Name'''||'''CF Export'''||'''CF Import'''||'''NetCDF Java'''||'''Updated'''||'''Note'''||
