Changes between Version 4 and Version 5 of NetCDF_Improvements
- Sep 1, 2011, 9:48:25 AM (13 years ago)
NetCDF_Improvements
v4 v5 19 19 * [http://cf-pcmdi.llnl.gov/documents/cf-conventions/1.5/cf-conventions.html CF-1.5 - NetCDF Climate and Forecast (CF) Metadata Conventions] 20 20 * [http://ferret.wrc.noaa.gov/noaa_coop/coop_cdf_profile.html COARDS conventions (1995 standard that CF Conventions extends and generalizes)] 21 * [http://cf-pcmdi.llnl.gov/conformance/compliance-checker/ CF compliance checker] [http://pypi.python.org/pypi/cfchecker/2.0.2 (python script)] 21 * [http://cf-pcmdi.llnl.gov/conformance/compliance-checker/ CF compliance checker] [http://pypi.python.org/pypi/cfchecker/2.0.2 (python script)] - don't use to validate grid structure 22 22 23 23 === Issues with the current implementation === 24 24 * NetCDF created by GDAL not CF-1.0 compliant for geographical grids (issue #2129) - patch submitted 25 25 * netcdf driver does not read and write CF-1.0 coordinate system properly for projected CRS (issue #2893) 26 * support for read and write of projected coordinate values 27 * export std_parallel variables into a single standard_parallel netcdf attribute 26 28 * support packed data (with add_offset and scale_factor) properly - I don't see where they are used, must be tested 27 29
