| 3 | |
| 4 | == Report 14 == |
| 5 | |
| 6 | From: 2007-12-01 |
| 7 | |
| 8 | To: 2007-12-15 |
| 9 | |
| 10 | === Tickets === |
| 11 | |
| 12 | #910 ESRI ASCII GRIDS: Error reading last line |
| 13 | |
| 14 | #1442 Feature.GetFieldAsInteger does not behave correctly on non existant field |
| 15 | |
| 16 | #1538 Static Proj4 + Jasper fails under default ./configure |
| 17 | |
| 18 | #1567 Patch for HFA no-data value support |
| 19 | |
| 20 | #1645 configure does not check for SQLite header and library |
| 21 | |
| 22 | #1988 If Xerces is on by default, the Xerces include dir is not correct |
| 23 | |
| 24 | #2017 default XML namespaces should be consistent |
| 25 | |
| 26 | #2031 CreateGeometryFromJson/ExportToJson |
| 27 | |
| 28 | #2036 CPLAtof() - different results than atof() |
| 29 | |
| 30 | #2050 expat configure failure on ubuntu 7.10 |
| 31 | |
| 32 | #2064 Building with Visual C++ 2008 Express Edition |
| 33 | |
| 34 | #2065 GDAL apps over-linking issue |
| 35 | |
| 36 | #2066 Remove libgeos from linker flags |
| 37 | |
| 38 | #2067 configure detects SQLite even if not available |
| 39 | |
| 40 | #2068 Strange Python dependency to libNCSCnet |
| 41 | |
| 42 | #2082 OGR warns about 'Multi-column primary key' but there is none |
| 43 | |
| 44 | #2088 pycc errror while building Python on Solaris 10 |
| 45 | |
| 46 | === Other activities === |
| 47 | |
| 48 | * Continuous testing |
| 49 | * Meetings, RFC documents review |
| 50 | * Providing support on IRC #gdal and mailing list |
| 51 | * ~20 posts to the gdal-dev mailing list |
| 52 | * Buildbot maintenance |
| 53 | |
