Changes between Version 8 and Version 9 of MaintenanceReportsByChaitanya
Oct 28, 2009, 10:04:19 AM (14 years ago)
chaitanya
Update for the duration of Sep 25, 2009 to Oct 27, 2009
  • MaintenanceReportsByChaitanya
    v8 v9
    11= GDAL Maintenance Reports by Chaitanya kumar CH =
    3 === Sep 9, 2009to Sep 24, 2009 ===
     3=== Sep 25, 2009 to Oct 27, 2009 ===
     5#3156: Fixed the problem with xerces library's changes between versions 2 and 3. Also found and fixed a bug that caused segmentation fault in ili driver.
     7#2270: Tested and applied the patch for HDF5 block size recognition
     8
     9#3161: Reviewed proposal for gdal_merge.py
     10
     11#3129: Looked into the norms of contour orientation and gone through the code to get a feel fo the algorithm.
     12
     13#3166: Researched netcdf and hdf specifications for the size issue.
     14
     15#3154: Configure snippet is not truly able to manage both netcdf3 and netcdf4
     16
     17Read up on autoconf
     18
     19gdal-dev
     20
     21=== Sep 9, 2009 to Sep 24, 2009 ===
    422
    523#2930 Cleanup Win32 Compile Warnings
