Changes between Version 1 and Version 2 of LibKML
- Jun 22, 2010, 8:13:40 PM (14 years ago)
LibKML
v1 v2 13 13 }}} 14 14 15 That solution does not include all the needed project, so you should doit after loading the solution on VS 2005.15 That solution does not include all the needed project, so you should add it after loading the solution on VS 2005. 16 16 17 17 {{{ … … 20 20 }}} 21 21 22 Note that from the SVN checkout there are more than source code but also some pre-build third part libraries. 22 Note that from the SVN checkout there are more than source code but also some pre-build third part libraries. Those libraries are not build by the existing VS projects but they are going to be needed to build the LibKML driver. 23 23 24 24 {{{ 25 25 .\libkml\third_party\expat.win32\libexpat.lib 26 .\libkml\third_party\expat.win32\libexpatMT.lib27 .\libkml\third_party\expat.win32\libexpatw.lib28 .\libkml\third_party\expat.win32\libexpatwMT.lib29 .\libkml\third_party\googletest-r108.win32\debug\gtest.lib30 26 .\libkml\third_party\googletest-r108.win32\release\gtest.lib 31 .\libkml\third_party\uriparser-0.7.5.win32\debug\uriparser.lib32 27 .\libkml\third_party\uriparser-0.7.5.win32\release\uriparser.lib 33 28 .\libkml\third_party\zlib-1.2.3.win32\lib\minizip.lib … … 35 30 .\libkml\third_party\zlib-1.2.3.win32\lib\zlib.lib 36 31 }}} 32 33 You should make sure that you have build the whole solution, all the projects, in Release mode preferably. 37 34 38 35 Now, you should update the file "nmake.opt" at GDAL root folder, uncommenting the lines related to libkml and changing LIBKML_DIR to reflect where LibKML is in your system. … … 51 48 $(LIBKML_LIBRARY)/minizip_static.lib \ 52 49 $(LIBKML_DIR)/third_party\expat.win32/libexpat.lib \ 53 $(LIBKML_DIR)/third_party\uriparser-0.7.5.win32/ debug/uriparser.lib \50 $(LIBKML_DIR)/third_party\uriparser-0.7.5.win32/release/uriparser.lib \ 54 51 $(LIBKML_DIR)/third_party\zlib-1.2.3.win32/lib/minizip.lib \ 55 52 $(LIBKML_DIR)/third_party\zlib-1.2.3.win32/lib/zlib.lib
