Changes between Version 3 and Version 4 of JP2KAK
- Aug 31, 2007, 3:45:29 PM (17 years ago)
JP2KAK
v3 v4 1 1 JP2KAK is the [http://www.kakadusoftware.com/ Kakadu] based [http://www.gdal.org/frmt_jp2kak.html GDAL Driver] for JPEG2000 image data. There are several other JPEG2000 drivers as well (JPEG200 - JasPer, JP2MRSID - MrSID SDK, JP2ECW - ECW SDK). The Kakadu library is proprietary, but can be licensed under reasonable terms for various uses. Unfortunately it comes with a slightly unusual build system which makes it hard to build against. 2 2 3 == Unix/Linux Builds == 3 == Unix/Linux Builds by mloskot == 4 5 The following guide walks through steps required to build Kakadu 6.0 and GDAL with JP2KAK driver support on 32-bit Linux machine. Instructions presented here have been tested under Ubuntu Linux. 6 7 * Unpack Kakadu 6.0 sources to preferred location: 8 9 {{{ 10 $ cp v6_0-00256n.zip /usr/local 11 $ cd /usr/local 12 $ unzip v6_0-00256n.zip 13 $ mv v6_0-00256N kakadu-6.0 14 }}} 15 16 '''Note:''' I assume you have sufficient privileges to operate in ''/usr/local'' directory or you have chosen different location. 17 18 The location ''/usr/local/kakadu-6.0'' will be used as building workspace and also as installation directory, because there is no ''make install'' step when building Kakadu. 19 20 ---- 21 22 == Unix/Linux Builds by Frank == 4 23 5 24 This is how I setup to use Kakadu 6.0 on my 64bit linux system with GDAL 1.4.x. Other makefiles exist for 32bit linux and a few other variations. You may have to fiddle with the makefiles some if your environment is odd.
