Changes between Version 6 and Version 7 of GdalOgrInJavaBuildInstructions
- Jan 30, 2011, 12:15:45 PM (13 years ago)
v6 v7 22 22 23 23 Binary distributions are available, so compiling isn't necessary. 24 25 == Set up environment variables ==26 27 a. In the Control Panel, open up System. Switch to the Advanced tab and click on Environmental Variables.28 29 b. In the System Variables pane, look for CLASSPATH. If it exists, click on "Edit" and ensure that "." and "..\gdal.jar" are included. Individual items are separated by colons. If CLASSPATH does not exist, click on "New" and add CLASSPATH with the same two locations.30 31 c. Do the same for PATH. Ensure that "''<java-dir>''\bin" and "''<ant-dir>''\bin" are included in PATH.32 24 33 25 == Download and Configure GDAL == … … 89 81 The gdal.jar will need to be in the class path. 90 82 83 84 == CLASSPATH == 85 86 It may be desirable to modify the CLASSPATH globally. This can be done like this: 87 88 a. In the Control Panel, open up System. Switch to the Advanced tab and click on Environmental Variables. 89 90 b. In the System Variables pane, look for CLASSPATH. If it exists, click on "Edit" and ensure that "." and "..\gdal.jar" are included. Individual items are separated by colons. If CLASSPATH does not exist, click on "New" and add CLASSPATH with the same two locations. 91
