Changes between Version 7 and Version 8 of GdalOgrInCsharp
- Apr 6, 2007, 2:41:39 PM (17 years ago)
GdalOgrInCsharp
v7 v8 16 16 The GDAL/OGR CSharp interface is fairly new and the first official version was published first along with the GDAL 1.4.0 release. As of the 1.4.0 release there was a substantial evolution in the interface based on the various user requests. Some of these changes in the current version (1.5.0) were backward incompatible with 1.4.0 and currently the transition to the current development version is suggested for the interface users and 1.4.0 is considered as deprecated. 17 17 18 == The main differences between 1.4.0 and 1.5.0, and the migration steps for the existing code == 18 The main differences between 1.4.0 and 1.5.0, and the migration steps for the existing code: 19 19 20 === Support for the enumerated types of the C# interface (#1559) === 21 22 === C# namespace names and module names follows the .NET framework naming guidelines (#1560) === 23 24 === Changed the names of the Windows builds for a better match with the GNU/Linux/OSX builds === 25 26 === The gdalconst assembly is now deprecated === 27 28 === Added support for Dataset.BuildOverviews (#1552) === 29 30 === GDAL C# libtool build support (#1558) === 31 32 === CreateFromWkb support (#1565) === 33 34 === Dataset.ReadRaster, Dataset.WriteRaster support === 35 36 === Examples added === 20 * Support for the enumerated types of the C# interface (#1559) 21 * C# namespace names and module names follows the .NET framework naming guidelines (#1560) 22 * Changed the names of the Windows builds for a better match with the GNU/Linux/OSX builds 23 * The gdalconst assembly is now deprecated 24 * Added support for Dataset.BuildOverviews (#1552) 25 * GDAL C# libtool build support (#1558) 26 * CreateFromWkb support (#1565) 27 * Dataset.ReadRaster, Dataset.WriteRaster support 28 * Examples added 37 29 38 30 == GDAL/OGR CSharp interface compilation == … … 42 34 == Using the GDAL/OGR CSharp interface == 43 35 44 === Adding reference to the GDAL/OGR assemblies 36 === Adding reference to the GDAL/OGR assemblies === 45 37 46 38 === Using the interface classes === 47 39 48 40 === Handling GDAL raster data === 49 50 = GDAL/OGR CSharp sample applications =51 41 52 42 = Useful Links =
