Changes between Version 2 and Version 3 of GdalOgrCsharpCompile
- Mar 3, 2008, 1:15:57 PM (16 years ago)
v2 v3 70 70 }}} 71 71 72 == Using static vs. dynamic linking with the gdal libraries ==73 74 The default approach embeds the gdal/ogr code into the corresponding *_wrap.dll to minimize the dependency of the created files. In some cases you might want to link against the core gdal*.dll instead. To enable this option comment out the75 76 {{{77 CSHARP_STATIC_LINKAGE = YES78 }}}79 80 entry in the csharp.opt file.81 82 72 == Using MONO on Windows == 83 73 … … 92 82 == Compiling on a WIN64 platform == 93 83 94 You can compile GDAL on a Win64 platform creating either Win32 or Win64 binaries. You should take care of setting up the proper environment variables for the corresponding compiler .84 You can compile GDAL on a Win64 platform creating either Win32 or Win64 binaries. You should take care of setting up the proper environment variables for the corresponding compiler by using the proper vcvars.bat or using the Visual Studio 2005 x64 command prompt. 95 85 96 86 For creating Win64 binaries you should compile the gdal core and the C# interface using the 64 bit compiler version, and specify WIN64=YES in nmake.opt.
