Changes between Version 13 and Version 14 of GRASS
- May 24, 2009, 11:00:07 PM (15 years ago)
v13 v14 5 5 The right order of steps to perform is, briefly: 6 6 * build GDAL '''without''' GRASS support 7 * build GRASS 7 * build GRASS pointing to your new GDAL 8 8 * add your GRASS library path to /etc/ld.so.conf and run ldconfig 9 * build GDAL '''with''' GRASS support9 * build GDAL's GRASS plugin ''OR'' completely rebuild GDAL '''with''' GRASS support. (building the plugin is easier; do that) 10 10 11 11 == Prerequisites == … … 22 22 23 23 == Building GDAL and GRASS driver plugin == 24 25 === First build GDAL without GRASS === 24 26 25 27 * Configure GDAL sources '''without''' GRASS support: … … 50 52 }}} 51 53 52 == Build GRASS plugin == 54 === Next build GRASS === 55 56 * ./configure GRASS --with-gdal=/path/to/gdal-config 57 58 === Finally build GDAL's GRASS plugin === 53 59 54 60 * [http://download.osgeo.org/gdal/ Download] latest sources of GRASS plugin where the package file name is gdal-grass-X.Y.Z.tar.gz, ie. [http://download.osgeo.org/gdal/gdal-grass-1.4.3.tar.gz gdal-grass-1.4.3.tar.gz] (1.4.3 plugin is fine with any 1.4.x GDAL). Unpack the source package: … … 77 83 }}} 78 84 85 === Confirm === 86 87 {{{ 88 gdalinfo --formats | grep GRASS 89 ogrinfo --formats | grep GRASS 90 }}} 91 92 should both show some information on the GRASS driver. 93 94 79 95 = Open Tickets = 80 96
