25 | | If you are having error messages with the ArcSDE raster plugin (`gdal_sde.dll`) , you may need a different dll. Here's are new ones linked against FWTools1.3.9. (You'll need to manually rename it to be `gdal_SDE.dll`, depending on the version of ArcSDE you're using) |
26 | | http://iowa.hobu.biz/gdal_SDE_91.dll |
27 | | http://iowa.hobu.biz/gdal_SDE_92.dll |
| 25 | === SDE Support === |
| 26 | |
| 27 | For SDE support in FWTools for Win32 1.3.9 and later it is necessary to manually install an appropriate plugin manually. The plugin should be placed in the gdal_plugins directory (eg. C:\Program Files\FWTools1.3.9\gdal_plugins) which may need to be created manually. Here's are new ones linked against FWTools1.3.9. (You'll need to manually rename it to be `gdal_SDE.dll`, depending on the version of ArcSDE you're using) |
| 28 | * http://iowa.hobu.biz/gdal_SDE_91.dll |
| 29 | * http://iowa.hobu.biz/gdal_SDE_92.dll |
