Changes between Version 4 and Version 5 of FAQMiscellaneous
- Mar 31, 2009, 1:16:45 AM (15 years ago)
FAQMiscellaneous
v4 v5 73 73 74 74 If you intend writing code using GDAL/OGR that will not require recompilation when run against different GDAL/OGR versions, you should try 75 to stick to the C API when possible. Alt ough the changes in the C++ API are generally made in a upward compatible way, the C++ ABI75 to stick to the C API when possible. Although the changes in the C++ API are generally made in a upward compatible way, the C++ ABI 76 76 might change from a minor release to another one (for example from GDAL 1.5.0 to GDAL 1.6.0) due to additions of new virtual methods, new 77 77 member variables to core classes, etc.
