Changes between Initial Version and Version 1 of FAQGeneral
Apr 22, 2007, 10:38:19 AM (17 years ago)
Mateusz Łoskot
Crated FAQ General
  • FAQGeneral
     1= FAQ - General =
     3[[PageOutline(2,,inline)]]
     5=== What is GDAL? ===
     7GDAL name is usually used to name one of following:
     8
     9 * project of translation libraries for raster (GDAL) and vector (OGR) data formats, so in this case ''GDAL = GDAL + OGR''
     10 * translator library for raster geospatial data formats.
     12=== What's this OGR Stuff? ===
     13
     14The gdal/ogr tree holds source for a vector IO library inspired by [http://www.opengeospatial.org/standards OpenGIS Simple Features]. In theory it is separate from GDAL, but currently they reside in the same source tree and are somewhat entangled. More information can be found at http://ogr.maptools.org. It is my plan to properly fold OGR into GDAL properly at some point in the future. Then GDAL will be a raster and vector library.
     15
     16=== What exactly was the license terms for GDAL? ===
     17
     18The following terms are the same as X windows is released under, and is generally known as the [http://www.opensource.org/osi3.0/licenses/mit-license.php MIT License]. It is intended to give you permission to do whatever you want with the GDAL source, including building proprietary commercial software, without further permission from me, or requirement to distribute your source code. A few portions of GDAL under under slightly different terms. For instance the [http://www.libpng.org/ libpng], [http://www.ijg.org/ libjpeg], [http://remotesensing.org/libtiff/ libtiff], and [http://remotesensing.org/geotiff/geotiff.html libgeotiff] license terms may vary slightly though I don't think any of them differ in any significant way. Some external libraries which can be optionally used by GDAL are under radically different licenses.
     19
     20{{{
     21Copyright (c) 2000, Frank Warmerdam
     23Permission is hereby granted, free of charge, to any person obtaining a
     24copy of this software and associated documentation files (the "Software"),
     25to deal in the Software without restriction, including without limitation
     26the rights to use, copy, modify, merge, publish, distribute, sublicense,
     27and/or sell copies of the Software, and to permit persons to whom the
     28Software is furnished to do so, subject to the following conditions:
     29
     30The above copyright notice and this permission notice shall be included
     31in all copies or substantial portions of the Software.
     32
     33THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
     34OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
     35FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
     36THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
     37LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
     38FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
     39DEALINGS IN THE SOFTWARE.
     40}}}
     41
     42=== How do I add support for a new format? ===
     43
     44To some extent this is now covered by the [http://www.gdal.org/gdal_drivertut.html GDAL Driver Implementation Tutorial], and the [http://www.gdal.org/ogr/ogr_drivertut.html OGR Driver Implementation Tutorial].
