Changes between Version 28 and Version 29 of ECW
- May 4, 2017, 6:04:42 AM (7 years ago)
ECW
v28 v29 5 5 == Download ECW JPEG SDK == 6 6 7 In order to use ECW format with GDAL, you need to download the "ERDAS ECW/JP2 SDK" from the [http://download.hexagongeospatial.com/ download-portal?ProductName=336677bc-d93b-6e30-89b7-ff00003c6ea8Hexagon Geospatial] website. The 4.3 or newer read-only SDK should be available for free download after agreeing to licensing terms. In order to write ECW or JPEG2000 files via the ECW SDK it is necessary to purchase a write enabled version of the SDK from Hexagon Geospatial/ERDAS.7 In order to use ECW format with GDAL, you need to download the "ERDAS ECW/JP2 SDK" from the [http://download.hexagongeospatial.com/search?lang=en&keyword=ERDAS%20ECW%2FJP2%20SDK&product= Hexagon Geospatial] website. The 4.3 or newer read-only SDK should be available for free download after agreeing to licensing terms. In order to write ECW or JPEG2000 files via the ECW SDK it is necessary to purchase a write enabled version of the SDK from Hexagon Geospatial/ERDAS. 8 8 9 9 If the out of date libecwj 3.3 SDK can be found, it can also be used. It has significantly different licensing details. Some tickets and discussion below are related to the 3.3 SDK.
