Changes between Version 12 and Version 13 of BuildingOnWindows
Show
07/22/08 10:37:33 (5 years ago)
condit
  • BuildingOnWindows
    v12 v13
    8989 * '''PNG_EXTERNAL_LIB/PNGDIR/PNG_LIB''': Used to be able to link gdal with an external PNG library. Uncomment these lines and correct the paths.
    9090
    91  * '''DODS_DIR/DODS_LIB''': Uncomment these lines and correct the paths to enable DODS/OPeNDAP support. Currently this is building with libdap 3.6.2. You'll also need the GNU regex.h for win32.
     91 * '''DODS_DIR/DODS_LIB''': Uncomment these lines and correct the paths to enable DODS/OPeNDAP support. Currently this is building with libdap 3.8.x. You'll also need the GNU regex.h for win32.
    9292
    9393I frequently forget to update the Windows makefiles when I add new files, so if something comes up missing consider comparing the file lists in the appropriate makefile.vc against the GNUmakefile or just contact me.
